so you finally diagnosed the issue? or still just blindly hoping
I pulled mine apart and it was mint
I had most of the symptoms you did and it was just a failing lift pump
put in a new a1000 and its back to being a rocket
You really don't get it.
One more thing to add, lol, I always wanted to try a set of 238/80 with my mods. Irate fuel system, srp1.1, and billet 38r. Who knows, if I don't get these 250/200 dialed I might try them. I doubt it though
thats prolly what I would do too..No performance what so ever really, but I am super happy with my truck. If and when it's time for injectors it's going to be such a hard decision on what to do, I've had such great luck with factory.
Like I said nothing really power making...
GTP38R
RIFFRAFF FRX
BEANS TUNES
DRIVEN PRE PUMP
stock oil.
I'm sure many of you started out here. But going with a better injector, is the power really worth it? I strive for reliability and nothing but a stock hpop will ever be in this truck
Thanks for the info. I should give a bit mor info on the truck as it sits. Right now it's got a PMR engine with good compression on 7/8 cylinders. There's a BTS in it and it's got exhaust, intake, gauges, and a 6 position from Beans. Few other little things like intake air heater delete, etc. I have a forged engine to go in and got some intake plenums to go on.
My current train of thought is
250/200s, 468, HBjr, Driven Diesel RR with fuel bowl delete, and maybe some headers.
Just looking to finalize my plans. I'd like to be around 500-550 hp, and more is even better, but really, this truck is a beater and if it can fry the tires on demand, I'll be happy.
Long term pipe dream is that the engine will eventually find its way in my '79 Bronco.
Carry on with your thoughts everyone? Am I out to lunch? Or on the right course. LMK.
id kill for a 7.3 in a bronco!
that is awesome!!! stock 400 ford or any work done to it? I loved my ole 400 ford motor I had in my 79 3/4 ton..This is the Bronco, putting in a 400 for now.
nice.. I had one of those worn out 351m's too.. lol... then had the 400 worked over a lil bit... .060 over bore, 3 angle grind on the heads, edelbrock performer intake, 650 holy, msd, and long tube headers... that bich would get with it really well.. save that 351. the block and heads are identical to the 400.. just in case you need them...Worn out 351M in it now. Got a donor truck with a fairly new stock 400 in it. It's the next project on the list.
Pssshhhh. My 77 ferd had a 390 with a 3 spd. It was rolling on 39s. It would get about 2 gallons to the mile....
lol.. pretty much the same boat if I even thought of crackin into the secondary shot....Pssshhhh. My 77 ferd had a 390 with a 3 spd. It was rolling on 39s. It would get about 2 gallons to the mile....
lol.. yepThis was that bad all the time. 4.88 gears. It was in the sweet spot cruising down the highway but literally zero efficiency. I had dual carbs on it initially and it didn't change the mileage much unless it was pinned to the floor. With a 3 spd manual it was not a real great setup. It was awesome in sand dunes. Not to get too far off the trail here but that is why I had mickey Thompson baja belted radials on my 00 at one point. Taking that thing to the dunes I would up putting the same rubber on my Super Duty and it made me realize how retarded a built 390 was. My Super Duty with a single pos 100 hp chip on 39" tires was better. Kinda like a super built 89 for with 40 grand worth of camber suspension and a built/sc motor and then you hand that guy a stock raptor and he realizes his 89 is a huge pile of buzzy cap lol.
Ha! Yeah me too, that'd be real niceI wish my truck would make 2 gallons per mile
