For Sale: ISB170 (CR 4BT) w/Allison 1000 - almost New old stock
Hotrodtractor
Mingo, Ohio
I can't believe you still have it.
That's what I'm saying! I guess I'm going to have to set it up and start it at some point if that is what it is going to take. I don't want to give away a unused engine.... I'll put it in something first.
powerlifter405
Butt Town
Electronically how hard would that be to bolt into a 94 bronco?
I have a line on a 12v super cheap but I wanted to use an alison 6spd but the 5spd behind my 4300lb bronco would work well too!
Hotrodtractor
Mingo, Ohio
The entire chassis wiring harness and diagrams are with the motor and transmission. You just need a throttle pedal. Add in a power and a ground and run and you could probably run it off the current harness. I would strip the harness down and remove everything that isn't necessary, but I don't think it would take anything more than some time.
Hotrodtractor
Mingo, Ohio
Bump! I'm getting ready to do some spring cleaning in the shop and this thing is either going into a chassis or going to a new home.
