Ford 7.3 Passenger Bank Dead
NitroJoe
Ft. Lauderdale, FL
Understood. I will setup an account to host.
Also I will test:
  1. Remove Chip and start record video
  2. Replace IDM with 'used' unit once it arrives
  3. Compression test passenger side
  4. Report findings
Thanks again everyone. I have homework after work.
NitroJoe
Ft. Lauderdale, FL
Here are two files.
1. Cold Start - Yes, it is a long hard start, prob due to pass bank being dead.
2. Under VC and injector inspection.
Cold & Injector inspection
My camera work stinks, was trying not to kill my phone or get hurt.
My fuel pressure gauge was going crazy, It is connected to the front head port on pass side. Don't understand how it could be that high, if accurate.
Let me know what you guys think.
All of these links take you to lime wire (hosting site) for the files.
Thanks again, Joe
Tiha
Super Moderator
Super Mod
Have you tested fuel pressure someplace before the head? or Other head?
That is too much pressure it would mechanically lock the injectors.
NitroJoe
Ft. Lauderdale, FL
I tested the bowl pre-filter. I will move the gauge to the post-filter connection and test again, take the return line off, blow it back to the tank, and listen for bubbles.
I do have an FPR rebuild kit that can be installed as well to ensure the spring pressure is not the issue.
DEEZUZ
NO PUKESTERS
NWI
Never had a DOA Dorman, but after about a year all the wire sheathing is cracked and splintering.
Plenty of other DOA Dorman things though.
NitroJoe
Ft. Lauderdale, FL
I did bench tests for continuity and ohms before installing, and they passed. I am awaiting the second IDM so I can continue testing.
The fuel bowl return line was disassembled last night. I put 100PSI through it to the tank and got plenty of bubbles. I will reassemble it with a new blue spring and poppet and then test the fuel pressure issue.
Lastly, test new (used) IDM with and without hydra chip. Also, I bought a harbor freight diesel master compression tester to test the passenger side (if I can get their fitting to screw into the head).
NitroJoe
Ft. Lauderdale, FL
Ok I'll do that once I verify compression. Parts were delayed coming in, now that I have them here is the latest.
New (Used) IDM yields same results. Passenger side dead.
Fuel pressure regulator was rebuilt with new housing, poppet and blue spring. My OTC gauge bounces around but its bouncing between 60-80 which I think is ok given the passenger side is not consuming fuel.
The harbor freight master diesel kit does not work on the glow plug, so I'm getting an adapter so I can compression test that side.
NitroJoe
Ft. Lauderdale, FL
Wait a sec, I have the OEM (used) one from the driver side before I replaced it and it worked. I can try that one on the pass side after I compression check. I am running low on funds trying to get this thing going.
Mesa, AZ
I doubt it’s compression, it would be very odd to have an entire bank so far down on compression that they won’t fire. Also, if it were that low on compression, you’d have diesel damn near running out of the tailpipe.
NitroJoe
Ft. Lauderdale, FL
I hear you, but I'm running out of options to test.
No codes, everything passes resistance and continuity checks.
I'll swap that UVCH tomorrow night and try to start it again. Am I at the swap injectors side to side stage? Wouldn't I need to replace all the Orings and crush washers again to perform that test? Such a hassle to move around injectors.
Humm.. In theory if I have no codes and unplugged an injector at a time on passenger shouldn't that trigger a code? Maybe I can do that, try to start, check codes, clear them and move to next injector to see if I can get some to fire.
Mesa, AZ
For a quick test not o ringing the injectors would be fine, as long as there aren’t any that are damaged. I wouldn’t run them for much longer than a couple trips around the block though personally. If the fault is internal in the injector, on the electrical side, unplugging them one at a time would work. Also when running it with the valve cover off check oil spillage from the injectors, and make sure it’s roughly the same as the other side, again, having 4 bad injectors and all 4 ending up in the same bank is damn near impossible, but still a thing to check.
NitroJoe
Ft. Lauderdale, FL
Latest update on this saga:
Compression tests complete on 1,3,5,7 All are 425 to 450. Keep in mind this is a harbor freight gauge so may be less.
Removed Hydra chip (with batts unhooked)
Installed new (used) IDM
Swapped old Ford UVHC to pass side
Started truck - pass side still dead, no codes again.
Turned off truck: Test 1 unplug 5 & 7 , no fire on 1 & 3, Test 2 - Unplug 1 & 3 , no fire on 5 & 7
Ideas?
  • Main harness bad
  • PCM bad
  • HPOP loosing pressure after start on passenger side (can test with gauge tomorrow)
    • I am noticing a very long crank even right after truck is shutoff. Weirdly so for new injectors and seals.
  • Truck is cursed and should be parted out.
  • Statistically speaking these many things should not be wrong. It should be a core issue affecting everything.
Props to 6.0 Tech on compression not being the issue.
Thanks, -Joe
Mesa, AZ
Ideas?
  • Main harness bad
  • PCM bad
Thanks, -Joe
Check voltage on the center pin of the valve cover gasket connector. Should be around 120v. Should be able to do this with the truck running. It would be even better if you can find something that will handle that much voltage for a visual load test, being a lightbulb or similar.
NitroJoe
Ft. Lauderdale, FL
I did a couple of posts back. It's showing 6-10 volts during firing for both driver and passenger sides. Apparently you need an oscilloscope to see the waveform for the 120v because it happens so fast. What I read anyway.
Is that an accurate statement?
Powerstroke Cowboy
Montana
Ideas?
  • Main harness bad
  • PCM bad
Thanks, -Joe
Have you Ohm tested the injectors? I seriously don't think this could be the problem.
DTC will test your PCM for 55 bucks. Plus for another 25 they will mount it in a vehicle and test it there as well.
You've tested the harness from the IDM to the injectors, right? I believe I've read you have? How about PCM to IDM? It's starting to sound like a bad harness or PCM.
You've rulled out so much I can't help but think your close.
The no codes are throwing a curve ball. Makes me wonder of it's a PCM problem.
