No problem. Here are a few installed pics, these had some custom powdercoating/engraving done. The normal kit comes with a machined alum hub as photographed with the kit layed out. Everything is machined here in the US from solid billet. We use Timken or Yukon bearings, Warn lockout hubs, 35 splined 4130 stub shafts. The biggest advantage with our kit is the bearing spacing is farther apart than any one else but our hubs dont stick out like some of the kits. Dyna Trac's kit is lower profile than ours by about 1" though. Our 99-04 hubs stick out 7" from the disk brake mounting surface to the furthest edge of the lockout. To my knowledge Dyna's kit is 6"ish but Im not certain. We havent finalized the design for the '05+ kits but we are going for a 6" or less with the bearings still spaced out like they are. Our kits cost $1650 for non ABS and $1750 for ABS models.
There is a guy running the spyntec kit on a dodge in my area and looks RETARDED!... trevor, when u get that 05 kit out i may look into it if the price is about the same. About the same price as 2 unit berings, 2 hubs, and odds and ends, soo why not?
