StrokenHard
- Joined
- Oct 1, 2013
- Messages
- 27
- Reaction score
- 0
Hey guys,
I think this is the right form for this, if not i apologize ahead of time.
now for my problem
I have an 03 with 190cc RCD injectors,banjo bolt upgrade,blue spring kit, SCT street tune for injectors..
up until about 5 months ago now i had between 65-69 psi, then one day i started it up and noticed my pressure was between 55-60, over time till now it has SLOWLY been less and less it is now between 45-49 and if i take off it drops to 40 and raises back as i pick up speed... i have replaced the spring kit as of 2 months ago, i have changed the filters 3 times and non of the times were they dirty, i have the test port exstension hose for my electronic Phantom pressure gauge, i have bled the hose for air and have found no air, i have no fuel leaks, and now i am beating my head trying to figure this issue out, i do not have much more money to put into this truck, i need your guys expertise!!!!
i appreciate anyone that can lead me in the right direction!!
P.S. after changing filters and spring kit i have found NO changes in pressure.... just stays Low
now for my problem
