sonic blue l
Ok this is what I've done, or am in the process of doing.
Ih pistons. (not coated, not cut). colt stage 2 cam. rcd push rods. Hamilton valve springs. port matched heads/ factory 6.4 exhaust manifolds. home ported /cut intake manifold. rcd intake elbo. 72mm rcd atmo turbo. stock high pressure (may do a bit of smoothing too it). Just canned h&s tunes, but I do have the mcc unlock. (just trying to decide who's tunes to go with). I do have stock head bolts, still thinking they should hold fine
Anyway, will this make a good truck for towing a 13,000 lb 5th wheel holiday trailer, 2nd will it be a nice fun drive to truck?
I was on the fence about the turbo, but from what I've read it should help lower my egt's while towing.
Thanks for any info/input.
