swinky
If that's the stainless mbrp I'd go for it. I know it sounds stupid but that's a pricey piece. If he did that I'd be willing to bet it was studded correctly. Sounds dumb but it's always worked for me.
I found an 08 f350 ccsb king ranch with 141k. It has h&s black max, intake, straight pipe with dpf delete, 2" level, egr delete, airdog 2, and mud tires. He said its throwing a code for the hpfp but it still runs fine so he thinks it could be the wiring harness. He wants 21,5. If it is the hpfp that's a big job, cab off right? Worth it? I'm deciding between these two trucks. And gotta get one soon. Thoughts?? Thanks guys
A 6.4 has more junk and a more expensive tuner to buy. Gotta buy an exhaust and egr delete on the 6.4 to get the tunes. Idk how much a 6.0 turbo costs but the good 6.4 tuners are $1800.
6.4 costs
Exhaust 300+
Higher end tuner $1800
Egr delete $200ish I think just to make that amount of power.
6.0 can probably be bought already bulletproofed as the op is doing with an intake an exhaust more than likely. Since the egr issue on the 6.0 is already taken care of he doesn't have to worry about that. One of the sct livewire ts on eBay is $900 for some form of a 3015r. Hutch and harpoon and a turbo and you'll be at 500. Plus you don't have to be a ford tech to work on it. Haha.
I'm under the impression that the 6.0s atleast the early years still had issues in the fuel tank. Hutch mod gets rid of the intank filter and eliminates the foot that falls off which creates air in fuel issues hutch mod fixes the air in fuel. Harpoon cuts the vent tube shorter so you can get the last few gallons in easier.
