OneStockQuik6.0
- Joined
- May 22, 2011
- Messages
- 335
- Reaction score
- 0
So how many of you guys are running this and what have been the benefits,Any issues when running low on fuel?
Thanks!
Thanks!
I literally ran my tank to the point that there was only fuel left in the sump itself and the fuel lines one time, removed the -an line and let hardly any fuel drain out, it was awesome.
I run an XDP unit, not much different than Hellmann's.
Can you post a pic of how its mounted on the tank?
cut a hole in the skid plate with a hold saw, i was going to, but I never seen anything but the road.
I want a sump, just don't want to give up my skid plate.
Sent from my DROID BIONIC using Tapatalk 2
Can you run a sump with the rest of the system stock?
No. It's made for an aftermarket lift pump
You actually could with a couple extra fittings if you really wanted to (not necessary IMO). It's only a different way to get fuel from the tank. Through the bottom instead of over the top.
