B.A.D Performance
- Joined
- Apr 27, 2014
- Messages
- 152
- Reaction score
- 0
ok quick run down. just rebuilt this motor everything is new. on first fire up it was perfect no problems. drove it around maybe an hour or so. the next day drove it some more. let the truck idle for a minute to pop the hood and check for leaks. truck died and wouldnt restart.
I have it narrowed down to a high pressure oil problem.
base oil pressure gets up to 60psi
oil resivoir is full
with the scanner hooked up when hot it only builds 400psi at 90%
so I tried unplugging the icp sensor. no change
changed the icp sensor, no change
cleaned the ipr no change
changed the ipr pigtail no change
brand new injectors. unplugged all injectors turned motor over. none were pissing oil.
checked all 4 oil rail plugs under the valve covers. all where good.
yet when the motor is stone cold it will start and purr like a kitten. idle at 530psi at 13%. then gets up to temp and icp drops and truck dies wont restart.
im figuring if my stealth hpop was bad then the truck wouldn't run at all.
any ideas would be greatly appreciated. I don't know what else to check
