TXlineman83
P0113 Intake Air Temperature (IAT) Sensor 1 Circuit High
Sensor is probably toast. Can you monitor intake air temp?
Yes. Getting that on sct now
IAT1 showing 90
IAT2 showing 43
No. Been running down the interstate last 6hrs
so your motor thiks its cold all the time. not sure if it will let you make power when it thinks that.
I had these codes this morning. Unhook the MAF and spray it with electrical cleaner. May be a little out in the plug in. Fixed me right as rain.
I hated trying to monitor with the SCT. I know EOT is degrees C and ECT is in degrees F. I can't remember, are both those temps in degrees F?
if you pull the turbos off i can almost guarantee the problem will still be there.
have you changed the rail pressure sensor yet?
on the IDS, try and ramp the rail pressure up
If I were you I would have given it back to the shop I paid immediately.
