Hissing from drivers side.
benjamindurtka
Sounds good. When do you want to bring your scanner over?
2001 F-250 cclb
7.3l 4x4
forged rods,
ebpv, muffler, dp80hp dd.
joe d
monroe mi
I still havent replaced my laptop and ae since someone stole it fcking low life scumbags.... Or i would bring it over... Sorry
joe d
monroe mi
Yea i had a laptop that was used just for ae and they stole that plus my snapon scanner and both my cordless impacts. I got reimbursed just havent replaced any of the electronics yet.
benjamindurtka
Anyone know if that torque pro app with the obd2 will do what I need for fuel and oil and icp?
2001 F-250 cclb
7.3l 4x4
forged rods,
benjamindurtka
I know it says it will. Just looking for someone to confirm.
2001 F-250 cclb
7.3l 4x4
forged rods,
benjamindurtka
Plugged it in for 20 minutes and it started right up. Guess I need to check the relay.
2001 F-250 cclb
7.3l 4x4
forged rods,
joe d
monroe mi
Yes and the connections on top and under the valve cover the wires burn sometimes. Check the relay first and be positive its good.. Glad that Glowplugs seem to be your issue.
benjamindurtka
I forgot to tell Dp tuner that I had a 15° hpop instead of a 17°...
Would that make a difference with tuning anyone? I'm waiting on a can back from Dp. Just wondering. Broke my new flexplate. It's warrantied.
I'm guessing those longer guide pins from the block on my old engine need to replace the shorter ones on my obs engine. Or Napa just has junk... any thoughts internet? Lol
2001 F-250 cclb
7.3l 4x4
forged rods,
benjamindurtka
The relay was bad. After a 4 day fiasco with an incompetent shop it got fixed.
Ever hear of a diesel mechanic that didn't know what I glow plug relay was? I thought the wiring was the problem because it was a new relay. Shouldn't have even taken it in. They only charged me for parts though.
2001 F-250 cclb
7.3l 4x4
forged rods,
benjamindurtka
my new engine had shorter house pins for the trans bellhousing than my new engine did. Would that likely be my reason for breaking another flexplate? What kinda other things should I check that would cause my flexplate to break?
2001 F-250 cclb
7.3l 4x4
forged rods,
joe d
monroe mi
Make sure the tc is in all the way.. Sounds like you found your issues tho... Sounds like it never was seated properly.
joe d
monroe mi
Yea if the pin was two long to seat all the way into the trans then was pulling on the converter and cracking the plate
benjamindurtka
No. To short. Didn't even go into the trans bellhousing. Just in the adapter.
2001 F-250 cclb
7.3l 4x4
forged rods,
benjamindurtka
Gotcha. Any idea if there is a tool for those pins or just vice grips and heat?
2001 F-250 cclb
7.3l 4x4
forged rods,
benjamindurtka
I think they just have something like red loctite holding them in. Being machined like they are they are very hard to get ahold of with anything. Maybe order new ones and try to get a hold of a welder to get a nut on the end and twist them out?
2001 F-250 cclb
7.3l 4x4
forged rods,
