Horrible squeeling from front axle?
WILD_PHIL
East TX
Yesterday my truck started squeling. I figured I had a break hanging up. I went ahead and drove it home. Got up this morning and looked at it. I noticed metal shavings on my passenger wheel so I pulled the wheel. Rotor looked like it could be replaced so I pulled it to. Brake pads looked like chit. I put new pads and rotors on and bolted everything back up. It sounds just as bad now. I figured I'd check my hubs and they are nearly impossible to turn by hand. After driving it down my drive way and back it looks like my rotor is ate up again. Not that bad but doesn't look new after a quarter mile. I Googled it and found this video of a truck making the same sound.
https://youtu.be/tNo2L5_bMwI
E99 F350/zf6/guages/arp/comp/stellite/ billet wheel/ bellowed... Need more fuel and more air.
WILD_PHIL
East TX
Shredded 4x4 hub. It's the worse case I've ever seen.
WILD_PHIL
East TX
Well all the bearings are shot
co04cobra
WV
If the inner spindle bearing is shot you'll probably need a stub shaft too.
WILD_PHIL
East TX
Stub shaft was actually good. Had to replace the bearing on it but that should take care of it.
WILD_PHIL
East TX
Until I can overhaul the front end.
WILD_PHIL
East TX
I'm pretty sure this stub shaft is shot. Agreed?
WILD_PHIL
East TX
Any ideas on the differences between the pre 3-99 and post 3-99 hubs? I can get 2 of the post 3-99 hubs for 115. A pre 99 is 90 bucks for 1.
co04cobra
WV
No difference in any of the hubs. And that stub shaft looks trashed?
Bluke
Colorado
The rotor hat is different on the e99. You can put l99 hubs on it but you need rotors too. I can't remember if you need anything else. Also I recommend timkin hubs. The cheapo from the parts house will go out pretty quick
WILD_PHIL
East TX
Any ideas why someone would disconnect the ABS wires?
pdumont01
CT
If the sensor ring in the hub is going bad it can cause false activation and the brakes won't work well, unhook sensor abs is deactivated and no more brake problem
Sent from my Nexus 6 using Tapatalk
co04cobra
WV
Did you mean 4x4 lock hub or bearing? Didn't see your post below the picture before. But that stub is trashed.
WILD_PHIL
East TX
I meant the hub bearing. I replaced the locking hubs in January
Swsignal5
I have a late model hub if u need one. Brand new oem Ford. Still in the box
Sent from my QMV7A using Tapatalk
WILD_PHIL
East TX
I picked up 2 of them for 115. I'm just going to do both sides. I need a pair of stub axles if you got em.
WILD_PHIL
East TX
Question. Do these trucks take the same u joints in the outter stub axle that they do on the rest of the truck?
co04cobra
WV
No. Cant remember the #s off the top of my head but they are different.
Front axle joints use inside C-clips while rear u joints use outside snap rings.
Few of the differences off the top of my head.
WILD_PHIL
East TX
Good call. I realized that right after I posted. I've searched for outter stub axle u joint and can't find chit.
