prototypemo
- Joined
- Oct 4, 2014
- Messages
- 85
- Reaction score
- 0
at idle icp is 580-600, just cruising which i can do but its sluggish and shifts stupid hard. At WOT icp goes to 3300-3600. Ill try unplugging the VGT and see what it does. as for boost, I have a manual guage tapped into my map that at WOT will shoot to 26ish, and on my scanguage it reads 25-27 at WOT, cruising at 30 it will hang out around 11-15. Ill get a video later today as ive been working nights so I can work on it during the day. As its stupid cold where i'm at and I cant fit into a garage...(lifted problems) also it has a tune on it, but I do not know what tune it is due to it coming from PO but it has been flashed. The reason I feel this is because I can hang neck and neck with my buddies 6.7 on his +50 tune. Ive cleaned vgt solenoid, pulled turbo and cleaned vanes a couple days ago. Not sure on EBP pressure while driving but ive seen it around 30. ill double check those few issues when I get up and there is day light. and lastly I gave in and ordered a new HPOP, should be here monday but ill still check those items you mentioned. appreciate the extra brain as mine is getting tapped.
