Just another 7.3 under the knife.
MeTo
Talked to the machinist today, it will be another two weeks before he even measures it. WTF?
Purchased a power steering pump, ac pump, dryer and variable orifice tube (Arizona trips). All current peripherals now.
Sandblasting is done. I will paint the usual stuff this week to throw on the block and heads when done.
New head bolts, which? Not going Arp, it's not a Viagra truck. OEM/IH?
Now that I have extra time. Thinking of switching the OBS valve cover gaskets to powerstroke??? The engine harness is detaped, degreased and eliminated unnecessary wiring (fuel bowl & etc).
Moved GPR to fender. Less stuff in the way when I work on it AND I will be.
I have too much time to think here. Maybe a 2014 steering box? Now would be the time.
Central CA Foothills
"I have too much time to think here. Maybe a 2014 steering box? Now would be the time."\
You aren't kidding there buddy.........I bought a Swamps engine because I didn't have time to build one. It has now been apart coming up on a year.
I'm just about to stop finding things to take a part........
Latest one: I pulled the cowl plate off to replace the hose going to the washer nozzle and clean out the the leaves. Noticed the sealant was failing so I gutted the wiper mechanism and prepped to paint the interior and bottom of the cowl with Mastercoat. Sure nice to just stand in the engine compartment to work on it though.
Here's the while I'm here list so far:
Pull inner fenderwells to get rid of deteriorated fiberglass sound blankets
Pull core support to replace with one with no cracks.
Paint frame up to firewall. Remove everything including steering box
Push back firewall so no more BS with down pipe and up pipes.
Build reinforcement plates for cracks in firewall after getting a bit carried away.. we'll see when the engine is in but I estimate you can at least put your whole hand between the firewall and everything.
Dismantle AC box and clean out (Yuck!! Highly recommended) Move vacuum reservoir for more valve cover clearance, cover AC box in sound deadener / heat reflector
Clean out cowl and vent areas, clean seal paint cowl with Mastercoat. (POR but better) RUST was staring under failed butyl. In a CA truck.
Replace all the tired butyl sealant in firewall.
Lube all wiper parts with penetrating spray gel teflon grease
Fix washer nozzle
Install power steering cooler in prep for hydroboost.
Install RSK (had it for some time why not no engine weight walk right up to it to work)
Install sway bars front and rear
New cab mounts.
Install electric fuel. Incorporate existing extra fuse and relay spots to make factory looking install. Using 2 stock SD pumps in parellell set up for redundant back up.
Going Irate T4 and installing intercooler so that goes in on the way back.
Considering reworking to put AC condenser in front of IC since 100 degrees is common for us.
Working on a custom Donaldson Statopore air filter (huge)
Installing valve covers backwards for intake to valve cover breather clearance.
Custom oil fill set up to allow above
Linex Valve Covers just to see if it quiets injector solenoid noise.
Jet Hot coat the manifolds and turbine housing.
Working on a 2 speed eddy current drive electric fan clutch
Installing US Gear exhaust brake.
Dissassemble, clean and re wrap wire looms
Probably forgot a few things......
Been thinking about a steering box that wasn't designed in the 70's (Part # starts with a D you know) Taked to a friend in business (does all my fleet but a lot of custom work too) says the new boxes are ok but not all that. Still thinking about it.
MeTo
That is an impressive list. I have many of those done and some haven't occurred to me. Thanks, I shouldn't have even read that. :)
One aspect I disagree with is moving the condenser in front of the IC. Instead, replace the stock orifice tube with a variable orifice tube (RockAuto ~$3) or a smaller one. Once the freon is evacuated, it only takes about 2 minutes and a ~$10 AC quick disconnect tool (Napa). I meet an AC guy in the Arizona desert and his AC air temp was 43 degrees. The variable type is best if you are in colder temps regularly, it helps prevent evaporator freeze ups. The variable type senses pressure. At idle, when AC pump pressure is lower. It shifts to the smaller orifice size to increase cooling. He recommended to only use MAX AC when outside temps are >95 to prevent freeze up.
Forgot another item. Mitsubishi 215 amp alternator. My Auto Electric guy is very impressed with these. He tested mine on the bench and it made about 180 amps at idle. He loaded it to 200 amps for a few hours and it didn't even get hot. He says one of the most robust diode bridges he's seen.
Located new clutch fork boot and ZF inner shift boot.
Looking for new cowl drains, they are located at the bottom of the cowl area behind the lowest rear part of the front fender. Nothing new. Found a pair on e bay but seller couldn't find them to ship so gave me a refund. They are like fish lips or an air cleaner evacuation valve. May adapt those since oem is discontinued.
MeTo
When I did my cowl, I threw them away. We boondock A LOT, so my truck is parked under trees for weeks. I mounted stainless steel screen under the cowl to prevent leaves and pine needles from getting in there. When I cleaned mine, there was about 8" of "compost" sitting above the "fish lips". My truck was from New Mexico so there wasn't enough moisture to collect and rust out the cab.
GM, did you replace the ball stud when you did the clutch fork. I found a Ford dealer who has some new old stock and reasonable.
The machinist schedule is beginning to be BS. I'm beginning to think I need to find a short block vendor? He will not state when it will be started or finished. Swamps is 1 to 3 months and more than I need? I might call them and check if they would consider a basic/stock rebuild? I'm not going to gamble on a pick-an-pull. BlackWater looks nice, but they have enough not happy customers.
I had the same long discussion on the reman before ending up at Swamps.
There are others that I entertained. Some are still possibilities.
Diesel Innovations was actually more reasonable than Swamps. I wanted my engine assembled with my parts and dyno'd so they were out but only on that.
Blackwater has a good standing with one member on here, he had good luck but since sold the truck. Looking broader on Blackwater you find some negatives.
MeTo
I called the machinist Monday morning and it's been 5 weeks and he hasn't touched it. Could /would not give me a date when he would get to it? So I picked it up and took it
to Baril's Engine Rebuilding in Green Bay. 3 days to get the measurements and it will be done in 2 weeks. Baril has 13 employees and opened in 1986.
I have everything ready when the block and heads are done.
One thing I'm scratching my head over is trying to clean all the sandblaster sand out of the oil pan. Sand got wedged in the seam between the pan and windage tray. Every time I clean, I get a few more sand particles. I'm seriously thinking I will buy a different pan because of that? Of course I have my weld in dipstick tube fitting in this pan. All the pans in the Wisconsin salvage yards are rusted crap.
MeTo
A new oil pan is on the way. Just need to make another weld in dipstick tube fitting and weld it in the new pan.
Magnum PD
VA
It’s a good idea to coat the oil pan with stuff like Linex or rhino liner.
MeTo
Good news! My block and heads will be done by the end of the week or Monday at the latest. They (Baril Engine Rebuilding) called to have me drop the harmonic balancer, flywheel and pressure plate off to finish balancing.
Line boring was not needed, saved some money there. The cylinders needed 20 cut, now there at 30 under. They were already 10 under since the original engine was warrantied with a Navistar long block at 74. It's interesting that the block serial number has been rubbed out.
I welded another dipstick tube adapter in the new oil pan, then Por-15 it. The frame rails, cross member and the rest of the crap under the engine got etched and a coating of Por-15 as well.
I found a couple of cracks in the radiator support that weren't there when I installed the intercooler. I'm sure they like the pin stripping are from the desert roads in Arizona. By the time my wife's second husband gets it, it will have a lot of character and a little attitude.
I will post some pics when I get the cast iron back.
MeTo
It's been a while, it's finally together and in the truck sitting on it's biscuits. Nothing hooked yet. I'm thinking it should be running by the end of the week?
There was some challenges, but nothing some perseverance and money couldn't solve. I took a lot of pics documenting everything. If there is any interest? I will take the time to post some.
The cylinders needed 0.20" to clean them up. There now 30 over. This was a previous rebuilt Navistar long block. The previous owner's sun-in-law dusted this engine terribly. All the intake valve seats needed to be replaced. Decking the block required 0.003". The heads were fine. The bottom end got new (still) 0.010" under bearings. The block did not need line boring. The pistons and rods got balanced and then the entire rotating mass with balancer and clutch in place. Yes, I remembered to align the index marks when installing the clutch. I decided to use the stock balancer, since I tow a light camper and it has never experienced yellow line since I have owned it.
Machining was ~$4,800. Is anyone interested in seeing the actual machining invoice?
I thought I might do a first start video? Probably not?
As for paint, I gave that some thought. In the end, I decided to paint it their true color. Diesel greasy bastard black!
I have been talking to a few people and doing some research into what a proper break in involves? There is basically two camps, the believers and the knowers. This is what I currently align with. I obviously stole this from another site.
[FONT=&quot]Part I
"Breaking-in" a new diesel engine. Many of the engine manufacturers claim that their engines do not require break-in. That is just pure baloney! Enough pestering and a few references to some of the Cummins shop manuals have painted a clearer picture. All engines require some kind of break-in period. This is even true with current technology. Although current technology provides the means of manufacturing engine parts with unimaginable precision, the manufacturer still falls far short of achieving the near perfect fit that a proper break-in will provide. “Break-in,” for the most part, is the allowance of the machined cylinder and ring surfaces to conform to each other’s shape during engine operation. This conforming or “mating” of ring and cylinder surfaces is the ultimate goal of a proper break-in. “Mating” these two specific parts will produce a very tight seal in each cylinder. A tight seal is very important because it prevents the escape of unburned fuel and pressurized gasses into the crankcase, while further preventing crankcase oil from entering the cylinder above the top compression ring. It is the intention of this article to help people understand more about the break-in process, and what happens or can happen during the first few thousand miles of engine operation.
During break-in, a small amount of compression blow-by, oil-fuel dilution, and oil consumption will be experienced. This is perfectly normal and quite common in new engines. Although acceptable at first it is imperative that these undesirable attributes be as close to zero as possible after break-in has been completed. Although the others are important, blow-by is the primary reason the ring and cylinder wall interface has to fit together so tightly. Diesel fuel needs to be introduced into an air environment that is under intense pressure in order for it to burn without an ignition source. When the fuel burns, the gasses produced multiply the compression pressure in the cylinder. Pressurized gasses that escape by means of the compression ring / cylinder wall interface are called blow-by gases. Pressure that escapes the cylinder in this manner results in a loss of energy. Whether it is pressure lost on compression or combustion, it is unable to be utilized to drive the piston through the power stroke. This loss ultimately results in a reduction of fuel mileage and power.
Today’s Diesels can take a "few" miles to fully break in. 10,000 miles is not an uncommon break-in period, especially for an engine like the Power Stroke Diesel. The reasons that break-in is such a lengthy process are generally attributed to engineering targets as well as the function of diesel combustion.
In terms of engineering targets, engine manufacturers produce diesel engines to sustain high torque loads over constant and extended load intervals. In other words, very durable parts are required to hold up to the rigors of diesel operating conditions. For example, The International Truck and Engine Company employ some very special parts in their 175 - 275 hp engines. The pistons used in these engines are manufactured from lightweight aluminum alloy, and are constructed with Ni-Resist ring inserts. The aforementioned piston combination is further complemented with keystone plasma faced rings. These rings help reduce oil consumption and can extend the life of the power cylinder further than ordinary chromium-plated rings. While chromium-plated rings continue to be produced for both diesel and gasoline applications, they are slowly becoming old technology. They still perform well but plasma faced rings have consistently shown superior performance.
When we consider the function of diesel combustion, we must first understand the engine dynamics that are associated with that process. In order for break-in to occur, a fair amount of heat, friction and resulting wear will have to take place before the compression rings will have “mated” with the cylinder walls. When the rings and cylinder wall are new, a modest amount of heat is created merely from the friction of the new rings passing over the freshly honed cylinder wall. While the heat from friction is significant, the real heat is created from combustion of fuel in the cylinder. When the fuel is burned, gasses are produced that expand and heat all of the cylinder parts. If enough fuel is introduced, the resulting combustion can create gasses that expand so much they will actually expand the cylinder wall and the compression rings. It is important to understand this because expanding these parts places additional pressure on them, which creates more friction and correspondingly more heat. This does not take into account the additional heat from combustion that will be added to the heat from friction. Heat is important to assist wear for break-in but too much can cause major problems. This is the reason we should not subject the engine to significant loading for the first 1000 miles of its operation. Loading heavily will introduce more fuel to the cylinder, and will add significant amounts of heat and pressure to the cylinder components. Couple that scenario with new rings on a freshly honed cylinder wall and we can only imagine the amount of friction and heat being produced and absorbed by the rings. Furthermore, the engine oil, lubricating the cylinder walls, will flash burn when it contacts the very hot rings. The burned oil will leave a hard, enamel like residue on the cylinder wall, commonly known as oil glazing. When the rings are permitted to operate under such high temperatures, oil glazing of the cylinder can happen very quickly. Once this glaze builds up, the only repair is a labor-intensive process that requires disassembling the engine and re-honing the effected cylinders. Oil glazing is a problem because it is typically not distributed evenly in the cylinder, and the spaces that exist between the ring and cylinder wall are either still there or new larger ones are created. Oil glazing is typically thicker towards the top of the cylinder and it builds up in the areas where heating is the greatest. The glaze has very smooth and friction free properties that do not allow it to be scraped away by the rings. This inhibits further metal-to-metal wear between the cylinder wall and rings, preventing further mating of ring and cylinder. Thus, those small gaps between ring and cylinder surface will never seal. These spaces will then allow pressurized gasses and unburned fuel to escape into the crankcase, while allowing oil from the crankcase to enter the cylinder above the top compression ring.
Well why not run the engine at idle or under no load? This is bad too. It can create a similar condition to glazing. The rings need to expand a little during this initial break-in period, just not so much that they overheat and flash the engine oil. The engine needs to be moderately loaded in order to break in correctly. Running the engine under very light or no load prevents the oil film placed on the cylinder wall from being scraped away by the expanding compression rings. The rings will instead “hydroplane” or ride over the deposited oil film, allowing it to be exposed to the cylinder combustion. The oil film will then partially burn on the cylinder leaving a residue that will build up and oxidize over time. Eventually this leaves a hard deposit on the cylinder wall that is very similar to the glaze left from flash burning. My caution to those just running the engine as a normal daily driver (without some loading) and especially those who love to idle their vehicles, expect some VERY extended break-in periods (up to 30,000 miles). Expect oil consumption forever due to oil glazing. The rings never really seat well if they cannot expand from the dynamics and heat that a load produces. Expect poor mileage due to the passing of compression and combustion gasses around the compression rings. Additionally, expect to see increased bearing wear and engine wear due to the fuel passing the rings diluting the engine oil.
Thus, we can see that heavy loading and light loading can cause some major problems. Moderate loading is the key to a proper break in for the first 1000 miles. It permits the loose fitting piston rings to expand into the cylinder walls allowing them to perform double duty: First, scraping oil off the cylinder wall, and second, to create friction that will promote wearing the two surfaces to each other’s proportions. Furthermore, moderate loading will allow the rings to get hot but not to the point where it will flash the lubricating oil supplied to the cylinder walls. [/FONT]
Part II
Once the rings and cylinder have "mated," they will have worn away a considerable amount of their roughness. They will wear slower than they did when they were new. This reduced wear rate indicates the end of break-in, and a decrease in oil consumption should be obvious to the owner / operator. Furthermore, blow-by and fuel dilution should also be reduced but may not be so obviously evident. Be aware that engines employing Plasma faced ring technology will take a longer time to break-in. These rings tend to wear far slower than chromium-plated rings. The plasma ring’s hardness allows it to wear the cylinder wall in a more aggressive manner while only polishing the ring surface. Eventually the cylinder wall wears to the shape of the ring and subsequent cylinder wear evolves to a polishing process. This extended process drastically improves the sealing potential of the cylinder, which will correspondingly reduce blow-by and the amount of physical wear on these components. Therefore, we can safely say that the plasma faced ring / Ni Resist insert combination greatly extends engine life. Unfortunately, the price of this better seal is a longer break-in period.
So the big question is: How long does it take for an engine to break-in? Outside of the rings being hard as rocks and just taking their own sweet time to mate to the cylinder bores, the greatest factor is how the engine is broken-in. Most engines will be broken-in after running for some time, but some ways of breaking-in an engine are far superior to others as they are more likely to produce low blow-by and near zero oil consumption.
Therefore, I will lay out some recommended DOs well as definite DON’Ts:
1. DON'T run the engine hard for the first 50 to 100 miles. It is recommended that the engine be operated around the torque peak (1500 to 1800 RPM) in high gear. This loads the engine very gently, and allows the internal parts to "get acquainted" without any extreme forces.
2. DON'T let the engine idle for more than five (5) minutes at any one time during the first 100 miles. (Even in traffic.) Remember those loose fitting rings, and possible fuel-oil dilution that were noted above? (Fuel Dilution is very common when diesels idle, even with well broken-in engines.) Well, if that fuel is allowed to contact the main and rod bearings during break in (not really good at any time), you might be looking at an engine that will always consume some oil and one that may not produce power or mileage as expected. In the first few miles of break-in, the bearings are mating to the crank, rods, etc. It is imperative during this time that the lubrication qualities of the oil remain robust. Fuel in the oil will reduce its ability to absorb shock and float the rotating parts in their bearings. Contact between bearings and journals will occur more frequently which will result in additional friction wear. This will ultimately reduce the tight tolerances between the bearings and journals. What was originally a tight fit will be sloppy and will never be able to mate properly.
3. DO drive the engine at varying RPMs and speeds until about 1000 miles. The idea is to alternately heat and cool the rings under varying RPMs. Manual transmission-equipped trucks are the best for this as they typically employ engine compression to slow the vehicle during normal operation, this constantly allows for varied RPMs. This can also be done with automatic transmissions, but it requires that you manually downshift the transmission into the lower gears while driving. Typically, most people with automatic transmissions operate their vehicles in Drive or Overdrive gear positions without making these manual shifts. When their vehicle is decelerating and the speed falls below 38 mph the transmission has little influence on engine RPM. This is because the torque converter unlocks and the auto transmission does not downshift to lower gears in the same fashion that manually shifting does. My suggestion to those with auto transmissions is to find an empty parking lot in the evening, and drive back and forth across it in the lower gears. (This can be done with standard transmission trucks as well.) Each time revving her up close to redline and letting engine compression slow it back down. This gets the rings a bit hot, but the compression braking allows the pistons to cool with high oil spray flow and no fuel load. Keep doing this for a number of runs, or until boredom sets in.
4. DO put a load on the engine at around 1000 miles, and get the thing hot! Diesels are designed to work, and in many cases, they operate best under a load. Baptize your engine with a nice "initiation load," to introduce it to hard work. Keep the revs up (but watch the EGTs), and make sure the coolant temps rise. Hooking up your trailer and finding some hills to pull works great for this. After the 1000 mile pull, just drive it normally, always making sure to let the engine get up to normal operating temps (no 1-mile trips to 7-Eleven). Towing is ok but remember to not overload and to monitor your gauges carefully erring on the side of caution. Under these conditions, I have seen most diesels completely break-in between 10-15,000 miles, and have always been able to tell that point from mileage gains. One may also notice that the "symphony" of the engine also changes slightly at this point.
We know that Engine Manufacturers have built today’s diesel engines using state of the art technology. They have fashioned parts to match in near perfect fashion. We can understand, through this article, that breaking-in this modern marvel of technology is more important than the manufacturers have lead us to believe. Furthermore, we can appreciate that following their claims can result in an engine that is wrought with inefficiency, sloppy fitting parts, and oil consumption problems. Following the guidelines and warnings set forth in this article will provide anyone who desires maximum efficiency and power out of his engine many miles of trouble free operation.
MeTo
Here are a few pics.
MeTo
More pics.
MeTo
How long does it take for a fresh rebuilt 7.3 to build oil pressure?
The machinist told me NOT to prelube it?
Everything but the cac tubes are installed. I bleed the fuel system, one tiny leak. One fitting needed tightening. I disconnected the valve cover gasket connectors to bleed the HPO. I.e. run a hose from the front of each head port back into the oil fill tube. I turned it over and NO LPO pressure! I have a new LPOP and had the machinist clean up the timing cover. I filled the oil filter and HPOP reservoir. The reservoir has held the oil for a couple of days now, evidently the check valve is working. I cranked it for abut 5 seconds and nothing.
HPOP reservoir was then empty. Reservoir not filling, pretty sure it's not the gauge?
I'm going to prelube it. I'm not sure if I can rent one or will need to throw one together?
I'm thinking I should raise the rear of the truck or over fill the oil to the base of the block?
I'm trying really hard not to have a brain cramp over this. It's the weekend. I'm going to drink some beer until Monday.
Have a good weekend everyone.
I would pull the glow plugs and spin it over with the IDM fuse out or the VC plugs unplugged.
I have a routine for this that is a bit tedious, but I think heads off a lot of issues that we read about with newly assembled engines or engines with new injectors installed.
Here is my routine:
Assemble the engine as normal except do not install glow plugs. Leave out IDM fuse or disconnect valve cover plugs.
We want to "motor" (spin over) the engine without compression overheating the starter and more importantly loading the rod an main bearings without oil pressure.
With an OBS that still has the original mechanical fuel pump we also prime the fuel system at the same time. Less important with electric fuel.
We do not want our new injectors firing with no fuel or aireated fuel.
The next prep item is to loosen the #2 orb Allen head oil rail bleed screws under the valve cover. They should have had new o rings put on them while things were apart. If they haven't been apart follow this to get them loose: DO NOT attempt to remove the plugs by just sticking an Allen bit in there and torquing away. The bit will snap 9 out of 10 tries. Use a flat ended punch at least the diameter of the plug head, or alternatively the largest flat ended punch that will fit in the Allen well and strike the head of the Allen plug hard 2 or 3 times. You aren't going to break anything. This works for all flush plugs in aluminum, iron or steel castings. HPOP reservoir plug especially. Now remove the foreword most (highest) oil rail plug. Leave the oil pressure sending unit on top of the HPOP reservoir ( for lube oil pressure) installed but loose so air can escape but an oil flood wont sneak up on you.
Continued
