Just dropped bessy off at BTS!!!
fordfreak4life
Talked to chris on the phone about an hour ago and he is on the way home..... Has a vibration under acceleration but it was there b4 the trans and worse after.... with the mod list he has I'm blaming it on axle wrap
vanderchevy18
Benton, Ks.
All true. Except now that i got home its under light exceleration too.
On edit: it seems to be lighter in 1&2 and the worst in 3rd. 4th and OD nothing. That's under light exceleration.
On edit #2: It was barely there before. While trying out the new tranny Brian gave me permission to give her hell. That was the first time it had ever seen ALMOST 100% power. Didn't start shimmying bad till I left leadhill.
Powerstroke Cowboy
Montana
you might have a bearing in the differantiol going out..
Were does the vibration come from??
Sorry to here yo are having trouble.. But glad you got your tranny in!!
Powerstroke Cowboy
Montana
Broken brake drum??
did it start before or after you did the LS mod??
On Edit: maybe the a couple of the for bolt are comeing loose that hold the Ring gear caryer on..
shooting at the moon here
vanderchevy18
Benton, Ks.
Brake drum???? Its 4 wheel disc. All superduties are.
I don't know. Y'all toss out some more ideas. I'll check it all tomorrow morning after I get the trac bars on.
vanderchevy18
Benton, Ks.
If it does end up being the trans (which I highly doubt), he'll be here for the Race 4 The Warriors June 4th. He can see what it feels like then.
Back at it again in the morn.
Chvyrkr
You don't have trac bars I'm guessing?
250/200's are gonna cause some wrap. Wrap is bad for the pinion bearings and ujoints.
If you lug it down to third gear speads in OD will it vibrate?
HaysKSFirefighter
Valley Center, KS
Here's a thought...we have a spare axle with the same gears sitting in your yard........just need to torch it out from under the other truck
I'm sure you can see where I'm going with this. Wanna add it to the list for tomorrow? LOL
