Erikclaw
Looks good. Mine is advertised as an 8" but looks taller. Looks like you could go to a dual stage coil since you have a foot of thread on the body.
Straight up Sik!
I did some digging and Eibach makes a helper spring that is 3" in length. It serves no purpose but to keep tension on the main spring should the shock extend, or drop out, beyond the main springs range.
With my set up the drop out is not possible so the helper spring is purely cosmetic. Which is ok for me. ADS quoted me 80.00 per helper spring with a weeks shipping and throw in ( foe fawee) the spring to spring couplers.
Summit has the springs for 60.00 each and they are is stock in Ohio. They want 25.00 per coupler, which aren't available till the 18th. The 3" coupler is the X factor.
I don't want to change the characteristics of the shock assembly since I'm sure there was a lot of factors that went into the set up I have now and don't wanna screw it up.
I want to say mine has a little more space between the coils, but they do offer a little. It is softer so it will collapse first then the main takes over.
Here is a little larger pic of my avatar... You can see what I am talking about.
You can see Layson's helper spring above the thread locking thingy that holds the main spring in its location.
