Little project for my parents first diesel
smcox1
It looks so good! Are you putting the same grille that your truck has?
Matt_P
Lima, OH
Looks great! You did a killer job! It's very cool of you to do that for them!
"3 can keep a secret if 2 are dead"
whs
Thanks guys!
Thanks! I have the chrome bar grille to go in it. Im having a new harley grille painted for my truck though so I might throw my old one on to see how it looks too
Looks good, I might have missed it but did you use wheel spacers?
Thanks! I put 2" wheel spacers on
Looks so good! Great work man!
Thank you!
Matt_P
Lima, OH
Well there was a little problem with the truck being low on power, it felt like it was loosing high pressure oil so I put the scanner on it and at full throttle it was at 85% ipr duty cycle and was only at 725-800 icp psi. So yesterday I installed a new IPR along with the new 05 front end and got the steering wheel all straightened out and running boards back on.
Untitled by mattpopiel, on Flickr
webb06
Seneca, MO
You pulled the intake to replace the ipr? On the last pic it appears that the paint line on both doors is way off? Maybe just the pic angle. Front end looks good though
Matt_P
Lima, OH
Looks great!
Thanks!
Yeah I had to pull the intake to replace the IPR since its an early 04 with the old style manifold. Since that back crossover piece on the old style manifold sits directly on top of the IPR. I wish I had a newer style intake to put on to eliminate all that extra work. Or even better if it was a later model so I wouldnt even have to pull the turbo to replace the IPR. The truck had been in an accident and when they fixed the door they left off the pinstripe. Understandable since the estimate on my truck that I just got valued those pinstripes at 300 bucks for the rear door. So Im gonna take the rest of the pinstripe off the truck and it will be coming off mine as well
webb06
Seneca, MO
Thanks!
If you have the special socket you don't need to remove the intake or turbo. I usually just remove the FICM and use a wobble with the special socket and it'll come out.
Ahh ok that makes sense then.
Matt_P
Lima, OH
Yeah I have the special socket and like you said I always use a wobble extension and that socket to get the IPR out on the later style 6.0s without removing the turbo or intake. It makes life a whole lot easier. I wish their truck didnt have the old crappy intake manifold
webb06
Seneca, MO
For some reason I was thinking I could do it on the 03 style intake too. Maybe I'm just dreaming
Matt_P
Lima, OH
Yeah unfortunately the IPR sits directly under that crossover piece on the old style manfiolds, even with the turbo removed its hard to see the IPR sitting under that manifold piece. The ICP you could definitely get to though.
Matt_P
Lima, OH
kyle43335
I cut the cross over piece off everyone of those manifolds.
Nice work...im not nit picking your work but shouldnt that front bumper piece be tan?
This truck isnt getting a tuner or anything is it?
