Major 7.3 Headscratcher
Powerstroke Man 6.4
Yes it will smooth out, just like when you unplug the ICP and the IPR d/c goes up and "estimates" 725 psi.
If all else fails and it smooths out with the ICP sensor unplugged and it defaults to the 7xx and idle smooth could you possibly put a chip in or pcm flash and tell a tuner to bump up ICP to the point where it smooths out at idle ie 7xx to fix the problem?
Or burn the sumbitsh to the ground, "I thiiiink its idling pretty smooth now."
Marty
Elkton, MD
But was it another stock pcm swapped in, or did he write some "stock" tune onto said pcm? Sorry if i missed it
Another stock PCM.
Not really the direction I am going with this. Something is wrong, and apparently has caused the truck to shut off on the customer. It needs to be figured out.
mandkole
Northwest
What's the EBP sensor showing?
^^^ we may not be on same page, but EBP was something that I was thinking about as well.. The power supply for the MAP, EBP, and ICP is all on the same line. Any shorts, chafing, etc? It does not explain the sudden dying.
Can the cam gear pickups for the CPS die?
Arisley
Arlington, Texas
Marty, have you checked the little fittings between the fuel lines and the heads. They may be clogged enough to have bad flow at idle, but once off idle, they flow fine.
Just a WAG.
Bustedknuckles
Just a WAG.
His icp is fluctuating, don't see how the fuel side would affect that. Someone earlier posted about checking LPO which is a great idea!
TurboM700
Minnesota
Scope the CPS sensor and see if it follows the rpm drop. I have seen once where a trucks cam shaft would walk causing a weird idle issue.
Also are you taking reading thru the computer or with anctually scope. I have seen reading thru PCM be off before.
I usally use my 4 channel modis for this so I can monitor a few channels at once.
Mike
Marty
Elkton, MD
Ebps reading 17 @ idle. Absolute reading. Does this with tune and without tune.
Lpo is fine, so is icp off idle or with sensor unplugged.
I inspected icp sensor face and checked resistance, no marking and was the same from one 7.3 to another. This is a stock 7.3 and the cam gear hasn't been off. I doubt it has cam gear walk for that reason too.
