V-Ref
On the side of the road at the moment....Can you do this in the truck or do you need to pull the motor?
What makes you think it's a head gasket?
I've done gaskets in truck. Much easier and quicker to just pull the motor.
Stud broke off?
I bet you could. It may be a pain in the ace though. Can you limp that doggy home?
Stud broke off?
I've had a H-11 break before but it was while torquing it not driving down the road. Wow
The forward H11 head stud & nut are missing? :jawdrop:
http://autorotate.smugmug.com/photos/i-PhZwKMk/0/XL/i-PhZwKMk-XL.jpg
I may end up doing it. Just wanted to see if it can be done in the truck. Thanks.
What was you target tq # on the hot re-tq's?
Just checked the tq wrench...it's still set on 135 ft/lbs. I no longer have the documentation from WOP when I purchased em....but I'm fairly certain that's the spec it stated...I wouldn't have just made that up. But I do hope that's right
All this time I've been a proponent of hot retorques...as I've gotten a good half turn or more on mine when doing it...
You should always take your wrench back to it's lowest setting after using it. Just saying.
Did you do those hot retorques with the engine actually hot? I heat the motor up and let it cool down. You torque a hot bolt and you would be amazed how much it will stretch.
Were those new studs when you put them in. If they were used, no hot retorque is needed, they have already been stretched.
What were you doung when that sucker popped?
Dam!! Dont see that everyday.
