mild or hot street build?
Groomzybanshee
St Joe mo
My s366 live for about 6 or so months my hx50 from river city made it two years and never failed same inj same tune... The hx 50 also pulled much harder
V-Ref
9 miles high @ 550 mph
Groomzy...can you spec out what a HX50 is comp/turbine inducer/exducer, what AR you had on it (it's in cm on HXs right?), and what injs you had?
brian89
Penisylvania
Revisiting this thread because i was told that a 7.3 can't make 650hp, but now i am making it a goal, now with 250/200's and an S467 and supporting mods is this do-able?
brian89
Penisylvania
I don't plan on spraying at all, ever, but what would be the least i would need? And is 650 still streetable and not to outta hand for a daily driver?
brian89
Penisylvania
I have a forged rod motor so is billet rods still needed? And doesn't an s467 with a 1.15 housing flow more than a 71mm?
MadDiesel73
Glen Burnie, Maryland
Must have billets for 600+ dd imo trust me (see avatar) I dont know if a s467 will be enough. May be good enough for just north of 600.
bruce
Middle east
mad diesel's avitar is a rod at 550 horse so i'd say if you want it to be reliable then year you need billet. there are a lot my turbos than just borg warner turbos. i think 300/200's, gtx4294, srp1.1 would be a mean combo. don't know why you want to daily drive a 650 horse truck though
brian89
Penisylvania
Ahh i see, and the home built trans was on a budget while i was in college because i wasn't making enough money to eat hardly so a trans will be part of the build, i would like to run a 75mm but i feel like that's a lot to run by itself
smoker00
Winnemucca NV.
My last setup was a 76mm precision turbo and 350ish cc/36lpm nozzles thats about 200 I think b-codes. no idea what it made for horsepower But you could dd no problem im at 4800 ft. And I picked it up in Denver CO. Like this it would make 50 to 60 pounds. Here got 16.1 mpg coming back from Denver. And it was on stock rods.. beat on it every day tell I destroyed that turbo.
Not saying the rods are not going to let go they will but so far so good..
My new turbo is a GTX4294R it is my hi pressure.. and fully built. Rods heads half fill.
But this truck dose not tow at all and it does get hot fast under the old turbo..
Hope this help good luck.
Black 02
Woodland, WA
Billet Rods, Girdle, Studs, Valve Springs, SRP1.1 or equiv, fuel mods, 350/200% nozzles, and a S468 turbo.
It'll get you to 600+. There are guys on here making more on the same setup. Especially if you spray it.
I wouldn't use forged rods for that kind of build. People are doing it on stock rods, but for how long is anyones guess. LOL
