Motor swap no start
jpow95
Did a motor swap in a 02 7.3 to another 02 7.3 installed motor and will crank no start ...icp is at 1500 and fuel pressure at 55 and fuel pulse is at .60 ms .. getting a slight bit of dark grey smoke and the glow plugs are coming on but I am not getting a wait to start light the fuel bowl heater is unplugged and I did check fuses the only fuse that didn’t have power was the power mirrored but that runs off a different circuit anyone have any ideas and cranking rpm is up at 200rpms
DEEZUZ
NO PUKESTERS
NWI
Do you hear injectors clacking while cranking?
Have you primed the fuel system?
