My mini build before the build
Jesse_01
Prince George, BC. Canada
EBP sensor blew out. Thought I had it on tight (like I said...amatuer) Tightened it then had to run too work. Will test when I get home.
Haha I have had that sensor blow out after I removing my egr cooler. Was on a round trip, had the wife reving up the engine with my head under the hood on the side of the highway.
It can be mofo to get to when the engine is hot.
Sent from my SM-N900W8 using Tapatalk
bricewise
Well that was it. Took her for a spin. With new boots, lot less smoke and a lot more go!
bricewise
God damn boots man. What am I doing wrong this is so frustrating. Whats an alternative to them? Is it the vanjen clamps or any other thoughts?
Couple videos after I got the gear head tune. Loving it.
A little smoke for WOT its tolerable for me.
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
WOT on Mild tune then boot blows off
YouTube Video
Gfulton - Sorry meant to respond sooner but will be moving to Tyler.
gfulton
Eliasville, Texas
Once you get to Tyler you'll be close enough to Matt for a live tuning session. Good luck with the boot, Colton should be able to help you.
4EverBoosted1
Try hairspray on the pipe and then slide the boot on..
Sent from my SAMSUNG-SM-G900A using Tapatalk
MorganY
college station, tx
Have someone weld a bead on the hard pipe
Please no.
OP take a picture of which boot it is. If it is the 90 degree boot on the bottom, cold side of the intercooler, there is a raised section inside one of the ends of the boot that needs to go on the intercooler side.
swinky
Eastern, Nc
Dremel the pipe with a sanding disk to rough it up then soak it in hair spray. Clamp on and tighten her up, let it sit for a little so the hair spray can harden.
bricewise
Soaking elbow in hairspray did the trick. But then forgot to turn off traction control and then phone died. You can't fix stupid. jfc
5 psi boosted launch
YouTube Video
Once I stop getting in the way of my truck with all these stupid mistakes, should move pretty well.
What are folks seeing for boost psi on non-vgt 66's?
jcain
Please no.
Oh, sorry! That only works on every boosted application except for diesels.
drunk on diesel
welding or rolling a bead on pipes works on diesels too! LOL
I think he was implying that something else was being overlooked. Any charge piping should have a lip on it, ESPECIALLY a diesel (which typically sees higher boost than gas applications)
4EverBoosted1
I think he was being sarcastic... But I'm not sure.
Sent from my iPad using Tapatalk HD
Jesse_01
Hairgel, the thick hardening type works like hair spray also. I was single when I had a 6.0. No hair spray around the house lol.
bigrpowr
<How I Fly
Administrator
glad it's working buddy !! with my 63 I was seeing 42 , with my 64.5 I'm seeing 45-47 . boost is just a number though, it isn't representative of too much.
