My rebuild/build tired of being basic
Mpoage
OKC, OK
Believe me I want to start slapping stuff on. whenever I get my turbo kit and duel fuelers im going to start the tear down. I am wanting to pull my valve covers and send them to powder along with my turbo piping and duel fueler brackets and pully!
Do you guys think studs would be necessary for my plans?
You do know that you have to pull the injectors and fuel rails off before the valve covers will come off, don't you?
Lynx
Awesome sounding! I'm interested in this build. Was planning on getting back into a superduty and running a similar setup. Glad I stumbled upon this. Wanted either 20x12, 22x11, or 22x12 on 33 toyo. I've had lifted vehicles all my life and now for something different. You'll get a sport tough look and performance. Very curious how this turns out. Good luck.
c.jank
Houston, TX
i kind of wished i had 22x12.. would love to run those on 33s with the drop, maybe next tire go around.. who knows i may have a new truck by that time anyways haha
Hendrys2009
Baytown, Tx
Im still debating dropping it. I may cut a coil and take the block out, but im going to see if it looks stupid at stock height first.
Hendrys2009
Baytown, Tx
Just got a little sneak peek from my powder coater! Looks like I'll be starting my tear down this evening!
Factory coil buckets done pearl white.
And some suspension pieces done in my legendary blue!
Sent from my iPhone using Tapatalk - now Free
jordan572
Getting at it, blue and white. One of my other favorite combos, I kind of like red and black too though :).
Hendrys2009
Baytown, Tx
Well here we are! Atleast I got to do it indoors this time. Got the front end tore all apart and found my stoping point for the night.
Also I wanted to share how I re-route my abs line so you don't have to zip tie it to your radius/control arms.
Excuse the dirty frame, I haven't had time to wash it in a while
MINK
London,OH
I have the beads in my tires, under 80mph they are good but after that not so much...still worth it in looks alone.
Very sharp truck, I dig it!
Hendrys2009
Baytown, Tx
Well got all my powder in and I pretty much have the front end all back together. I gotta say I am loving the way it is turning outs. It is deffinatly going to be a lot harder to clean now.
Hendrys2009
Baytown, Tx
Ok things have been a little crazy here lately with anniversarys slowing me down, but I finally made some more progress. Got the front end all buttoned up and ready for an alignment.
Next I assembled my factory leaf springs. Even though they can hardly be seen since the truck sits so low, I couldn't let myself leave them alone.
Removing my atlas leafs was a bear to do by myself. I don't remember them being as heavy when I put them in.
Next I installed my factory leafs, I chose to leave the factory block out in order to have a "reverse level" since I'm only running a 33" tire.
I then threw my wheels and tires on. Here's some teasers to get y'all through until I get the truck washed.
And last but not least a new background on my screen to piss the ole lady off
