Vader's Fury
jdc your link to pics doesn't work. Says page not found.
Edit: I found it by searching your user name.
Ok I have a lil time so i will try to layout my plans. First let me explain the purpose of this. I am currently working on a project that I have been doing research and planning on for the last 1.5 -2 years. I am planning to build an excursion that will be my ideal road trip vehicle. I commonly take weekend trips and vacations that include a decent size group of people so a large vehicle properly setup would fit perfectly.
Here is my audio/video plan. I will have a 10"-12" touch screen monitor located in the dash or custom center console to control my onboard PC. I will have 2 flip down screens for the rear seats. I also plan to install a port in the rear cargo area so that when going tailgating at a football game or a NASCAR race I will be able to setup a TV in the rear area and watch pre- game shows or whatever. That covers the viewing components.
Now for video sources, I am currently in the process of converting my DVD library over to digital. I plan to have a portion of this or if possible the entire thing onboard so i can watch any of them at any time. I also plan to install some type of game system. (ps3, Xbox 360 etc) I will determine what system when the time comes. For right now I will be using my old xbox for testing and such. I also plan to have on board wifi so that i can watch TV when i desire. (I have that setup with my cable already so that should be easy) as well as browse the internet when i need to.
I also still want the ability to listen to the radio and play CD's. Another thing with the sound portion is I want the ability to use head phones to listen to the 2 rear screens so that I will still be able to listen to the radio while I am driving. I hope to be able to set the headphones up to be wireless, but if not then they will be plug in and i will install jacks for all of them.
That is what i hope to have working from this whole system. Also the real kicker is I want to be able to control all of this from the front seats so i do not have to stop to switch videos for the kids or anything like that. I know my hopes are high and that, with having very little personal experience with this sort of stuff that I am in for a bunch of long nights banging my head against the wall and trying to figure everything out and make it work how I would like it to.
Any questions, idea's, comments and criticism is welcome except the "why waste your time, its not possible" type. It may not be possible to do it exactly how I would like it to work but I already know I can do it by having multiple control screens in the front console. I am trying to minimize that down to just one screen if possible. If not then using the least number required.
I'm going to start a build thread for my system. Do you think I should do it on PSA or MP3Car ?
I believe mp3car would give you more input and ideas to refine your system then here but I know that I would like to see you post it here as a resource for all of us to use in the future.
I bought the display and framework from a 2011 Honda Odyssey Touring Elite van yesterday. Its an ultrawide 16.2 inch LCD. I paid $75 for it on ebay.
Wow that sounds like a pretty good deal right there!! Hopefully it plays nice with the PC, which I would imagine it would.
I don't think that is a brain fart. I'm thinking that is the way its set up too.Bah, yea I had a brain fart and read that it had an HDMI port built in so I assumed it only needed a source connected and it was good.
I will.Hopefully that backseat HDMI connection is essentially just an extender for the connection on the monitor itself. The dual panel or single panel could make things interesting though. Post up some pics when you start cracking into it, or when you figure out what you are dealing with.
After 4 years of mine being installed in the truck it finally stopped working, wouldn't POST but would power up. Spent a couple hours trouble shooting and pretty sure it is the motherboard. Ended up pulling the trigger on some new hardware, went Mini ITX this time. Hopefully this will be the kick in the pants I need to finish my dash the way I want it.
Which mini ITX MB ? What case ? I would like something that mounted on the wall behind the rear seat, but I don't see many cases that will fit there.
I've always wondered about doing that. I'd be worried about 2 things. Something metal touching it and shorting things out and electromagnetic radiation betting noise into everything, like the AM radio, etc.No case, I will either mount it on the back wall like I did the old setup, or under the seat if I change things.
I wouldn't put it under the dash. Its so accessible behind the seat.It MIGHT, key word MIGHT fit in the dash but I think that will quickly turn into 10lbs in a 5lb bag, plus I already have all the cables setup for the guts to be behind the seat.
No built in WiFi ? Why AMD over Intel ?
Prices have fallen so much and performance is through the roof. I build an i5 based server last fall with an integrated graphics processor. It works well, but I don't even really use the graphics on it because its headless.and this CPU (or I guess APU) to go with it, http://www.newegg.com/Product/Product.aspx?Item=N82E16819106013
slapping a 4GB stick of ram in it too, should be waaay more than enough since the old PC was 2GB and ran 110% for what I asked it to do.
This is the first I have seen of the CPU/GPU combo (I have stayed away from the computer market for a while for fear of spending money) but seems interesting, hoping it works out good. Either way spec wise this little bugger should be 10x the machine my current desktop is.
[/quote] That thing would rock. Now I know why you weren't worried about not having Wifi built into the mobo.Only other change I am thinking is making a better wifi setup, I want to get an externally mounted antenna, either going to be through the cowl on the drivers side, or centered on the roof near the 3rd brake light. Something like this, http://www.amazon.ca/gp/product/B0035BGNWU/ref=cm_cr_rev_prod_title
How do you get around these issues ? I guess I could build a little box for it to sit in ?
How do you mount things to the back wall ? Do you put up a false wall and bolt to that or just drill the back wall or ????
What are you going to use for a power supply ?
So you still run a head unit with your PC system or are you headless ? If you are headless, how are you getting AM/FM and/or satellite radio ?
