It is much eaisier if you do take the U shaped tube off the turbos so that you can remove the polished pipe between the atmo turbo and the boost tube (u shapped tube). Once that is removed, the atmo will come out pretty easy.
Little bit of extra steps and you'd still be done already my man. Didn't I send ya a write up month ago or so?
did you undo the vgt actuator, remove the u-pipe and swing the fuel cooler out of the way? did you undo the uppipe bolts?
make sure the downpipe is completely undone. then pry on the intake manifold from passenger side (dont crush fuel line) and alternate from the drivers side.
the pins the turbos sit on are tapered. once it lifts the hp about an inch, the atmo will come up and out on an angle towards the passenger side.
check out my link...
http://powerstrokearmy.com/forums/showpost.php?p=834003&postcount=99
i tried to do it without disturbing much and it ended up taking longer that way.
I'll get flamed for this, but I let the uppipes go up top. I also keep em anti seized and they've been molested a lot lately... Just easier for me pop em up and split em that way.
