So I recently added 75% nozzles to my 175 warren injectors. The truck ran great with 175/stock but now it seems to have a few issues with the 75% nozzles added.
Is it normal to have a slight chug at idle once the truck warms up? Not really a miss but more like a choppy idle? It does not feel like a miss at all and goes away once I give it any throttle
The motor does not like to be lugged (below 1500rpms)... seems to run choppy (did not do that with 175/stock)
I am having egts issues even with new tunes. I tried running a tow tune and the results are all similar.
Boost levels all seem normal
Back pressure is also normal
With the new tunes it is not overly smokey (like it was with the 175/stock tune)
vgt duty cycle is acting normal
Truck runs and drives great
No weird smoke on startup
No weird smoke while idleing
I know the atomization is not as good on 75% nozzles... but do those numbers sound way too high?
I hate asking tuners for tons of different revisions so I was hoping to figure out a baseline or if something else is wrong before I keep asking for revisions.
- Idle = 350 (normal)
- WOT 0-80 = 1400 (normal)
- Cruising at 75mph = 950 (way higher than my normal)
- 1/4 throttle from 0-60 = 1200 (way higher than normal)
