Need help from some 175/75 injector guys
peixinho
The 6.4 intake Mani isn't a direct bolt on though is it?
Well... all the bolts line up but it is not bolt on. You have to do a few things to it first and then it bolts on. IMO if can can port your own 6.0 manifold then you can mod the 6.4 to fit the 6.0
loboost
What exactly has to be modified
peixinho
To be truthful I am not exactly sure yet. I have read a few write-ups but I have not done it yet myself.
Maybe I will do a really good write up when I do mine
Lilpooh
Sassamansville, PA
A couple tabs gotta be cut off. Fab up a alternator bracket. Either weld a intake elbow onto the manifold or make a bolt-on adapter plate. Cold side CAC pipe modified. Block or re-direct coolant passage between front cover and intake manifold.
