MPD new build
I installed 4.56's in it a couple years ago so unless Joe had it changed again that's what it has. It also got front and rear true-tracs and a complete front dynatrac hub & bearing conversion.
Ya you are correct Wayne. They are 4.56 a was trying to say. The True-Tracks will be replaced with a Dana 80 rear and Detriot lockers. I just went threw to many rears in a short time. The new One Up Offroad driveshaft should work good with the Dyna 80 rear.
The Dynatrack hub & bearing conversion Craig has to look at. It only had 3,000 miles on it and we had 1/2" of rock on the front rims. I hope they just need to be re torqued. Or I will need a new hub and bearing conversion again.
We went to put the new rims on and they were rocking in and out at least 1/2".
It is not the ball joints either. I looked up on there web site it said to re torque every 100 miles until play stops. I did not have the directions and nobody ever told me this.
I guess I know now...
Thanks
Joe
