New Intake Manifolds
SDS97_7.3
Finksburg, Maryland
The lines on the engine now are all mild steel.
Will be remaking all of them is stainless steel, So yes I will 1 each when done.
Yeah was just wondering, I looked back at the pics of the motor in the truck and figure it would be a lot easier if they were already made up if one does decide to let go.
neverkickn
AR
If you are talking about my old turbo, I was still running a stock turbo before I went to the twins.
I still have everything, so if I ever want to go back to stock I can.
I thought I remembered you using the 38r off of each manifold when you orrigionally built this. Guess I was mistaken.
Chrisf97305
Salem Or
Look what UPS just dropped off.
Chrisf97305
Salem Or
Mock up is now done. Its time to paint, and to make the lines again is stainless. Here is what it looks like.
Derek@Vision Diesel
Canby, OR
you need nitrous with those injectors your running and twins, seems like you could easily clean them up? What are you going to use it for primarily??? Can it even be used sled pulling?
Chrisf97305
Salem Or
The nitrous can not be used for pulling. Its just for drag racing and the dyno. And it will look good under the hood.
Chrisf97305
Salem Or
Got the manifolds back from the machine shop yesterday. Got them in last night. Its getting real close to being on the street again. Not done, just able to drive.
