NEW Irate Fuel system Billet Filter Blocks!
mattman347
Readyville TN
We released these a while ago but thought I would post them up on here too! They have been working great and take up a lot less space compared to our old system.
The standard Superduty system Here: here:https://www.iratediesel.com/irdie/product/idp-super-duty-standard-fuel-system/
Irate Diesel Standard COMPLETE fuel system. 5/8″ pickup tube, Parker 801-10 line from tank to IDP 304ss fuel bracket, Baldwin filters NEW IDP BILLET filter base , Deatsch Werks pump, 801-8 line to motor, Irate regulated return with Fuelab regulator and liquid filled gauge, 801-6 return line and wiring harness. System is complete from the tank forward and gets rid of all those pesky fuel bowl leaks and in tank pick-up issues. This system uses a pre pump screen filter that is serviceable before the pump to maximize flow to the pump and prevent starvation at the pump. From there it goes through a water separator filter then the final filter to prevent any contaminants getting to you engine!
Deatsch Werks pump comes with manufacturers 2 year warranty!
OBS system Here: https://www.iratediesel.com/irdie/product/obs-fuel-system/
Irate Diesel OBS Fuel System:
IDP 304ss mounting bracket, Deatsch Werks pump, Parker hose from selector valve to motor back to selector valve, IDP regulated return system, wiring harness, plug for valley and parker fittings. Our kit uses JIC fittings and includes all parts and pieces necessary for installation.
System installs from the selector valve forward so it still uses both tanks, and comes with everything needed to install including the hardline regulated return, this is a COMPLETE fuel system. This system ******S the fuel bowl and gets rid of the pesky leaks associated with the stock fuel bowl and has way better filtration. This system will support anything from stock up to a 250/200 injector or 550-600RWHP. If wanting to run larger, then pressure needs to be monitored to ensure proper pressures are maintained. (Draw straw pictured is not used on the OBS system) This system uses a pre pump screen filter that is serviceable before the pump to maximize flow to the pump and prevent starvation at the pump. From there it goes through a water separator filter then the final filter to prevent any contaminants getting to you engine!
*The new Deatsch Werks pump comes with a 2 year manufacturers warranty!!
*Comes with Stainless Steel Regulated Return kit!
Competition system here: https://www.iratediesel.com/irdie/product/idp-competition-fuel-system/
Competition Fuel System: Irate fuel bracket, Fuelab fuel pump, Baldwin filters with billet filter base, -8 line from tank to pump, -8 line from pump to motor, -6 line from motor to tank, 5/8″ pickup tube, Irate regulated return system, all fittings, wiring harness with waterproof conections, relay and circuit breaker. Add a sump for no tank drop install!! This kit comes with our stainless bent hardline fuel bowl ****** regulated return kit that eliminates the stock fuel bowl. This system uses a pre pump screen filter that is serviceable before the pump to maximize flow to the pump and prevent starvation at the pump. From there it goes through a water separator filter then the final filter to prevent any contaminants getting to you engine!
OBS trucks will be required to install draw straw or add a sump onto one tank, selector valve is too restrictive for this system! You can transfer from one tank to the other with a small pump so you still have the capacity of both tanks.
This is the system that is recommended for all injectors, and will support the largest of injectors made for the 7.3L!! It will also work with stock injectors if you are upgrading later!
These are in stock and ready to ship! If you have any questions feel free to call or email me!
