New turbo suggestions
mikah215
Truck is daily driven and I want to know what turbo would be best for the $ I was thinking a s366 but not sure I have 190/30 injectors studded bullet proof ficm and Sct tunes threw innovative.
My stock turbo boost around 35lbs what am I gonna expect with a new one.
03 f250 6.0 Sct with innovative tunes 5in exhaust coolant filter blue spring 190/30 bulletproof ficm&water pump aluminum rad STOCK STUDS 8in lift 20x14 on 37s
Merc82
I have been wondering about going non VGT myself, I run the same injectors.
mikah215
Mostly street very little towing.
mikah215
Vgt or no vgt
mikah215
What hp numbers will I be looking at?
03 f250 6.0 Sct with innovative tunes 5in exhaust coolant filter blue spring 190/30 bulletproof ficm&water pump aluminum rad Arp studs 8in lift 20x14 on 37s
mikah215
Id really like to be at or above 600
Who's got good prices
swinky
Eastern, Nc
Not gonna happen with 190s on 37s.
mikah215
37s are coming off
190s can't go over 600
mikah215
Close you think?
mikah215
Okay awesome where should I go to buy
mikah215
I knew I should have gotten 75 or 100s
swinky
Eastern, Nc
Yeah then you get to the point of needing more high pressure oil. It's never ending. 190/30s will make 600 all day on a generous dyno.
04cr450
harford county, maryland
^agreed. i made 638 hp on my 175/75's, supporting mods and a kc 68mm. eric live tuned it. but again, dyno is a dyno. there all fluffy numbers to me. Just a great tuning tool.
