non vgt chargers
Extended Power
When I ran a 64/71/70 on stick injectors, it was a blast to drive...
Absolutley NO worries of overheating anything, because there wasn't enough fuel, even with a Xtreme Race tune, to get the EGT's over 1250*F.
I have to mention that I was...and still am, running a Colt Cam though...
kyle43335
How does your truck drive with the stock sticks and the 64/70? Compared to stock turbo.
alittle lag while cruising, otherwise its great. the trucks running srl+,and you cant get it hot.. 1100 degrees tops
Extended Power
how were yall spooling rpm wise with that 64... when i ran mine it was not lighting like stock.
By 16-1750 I had about 2psi of boost already.
Driving on flat ground on the highway at 65-70mph (21-2200 rpm) I had 8-10psi boost. That's cruising, not accelerating.
I had a video showing the drive/ boost numbers on the highway....have to look for it....
smokinstroker
Texas
That's how mine was with a diverter, had a small leak but still.
My stock charger lights hard right now, and lights 13-1350 4 pounds at 1500
kyle43335
kyle are you running any cam in your motor?
stock.
i have a couple 6.4 cams i might experiment with?
my truck cruising has around 5 psi @15-1700.
keep in mind my manifolds are ported,and my ficm is 58v-flashed.(mild idp)
im waiting for a set of steedspeeds,as i believe it will make this charger/ injector combo a very fun truck to dd.
windrunner408
Thanks man for the info. Well I dont have any ported manifolds yet (I am definitely going to look to do a set of steedspeeds as well), I do have a 58v Mild IDP tuned FICM. I was asking about this because I am thinking this is the turbo I am looking to run for a single anyways when I do injectors and I am having some wierd stuff happening with my stock turbo and I would like to just do away with the VGT crap all together if I could.
Pizza pig
MD
yeah my stock charger lights instantly too its really fun driving this truck on the street
smokinstroker
Texas
My pos was in no way bashing a non Vgt, but just to give you an opinion from someone who has ran both large VGTs 62/70 64/70 and stock charger.
The boost being there so fast with a Vgt makes the truck a heck of a lot more fun.
Pizza pig
MD
Absolutely man, its nice have that instantaneous response the second you hit the pedal and pulls a 40mph rolling burnout
