Had same concern when I installed my digital gauge. Had to relocate my engine oil temperature sensor into my oil pan to get a accurate reading. When. I Tee'd mine into the oil filter housing but my oil temperature was around 30 degrees less the ECT. Now that's it's in the pan I have no problems. With the oil temperature reading low it was causing my tuner to reduce power until oil temperature got above operating temperature problem was it always read below 160 so tuner would not release full power.
Just something to think about.
I bought a bung from local race shop and I welded into my pan. Spliced connector to make it long enough to reach sensor in pan.
I used plumbing solder on my steel pan. I was a little iffy about it but It came out very nice and strong hasn't leaked been on for months. I figured if plumimg.solder can hold 100's lbs of pressure and melting point is above 400 degrees it should work. I can send a picture if you want to see.Thanks for the tip! I've been trying to decide how to get it to read correct again. I don't have reduced power, and don't play hard until I see my coolant up to temp. I'm just glad to see oil pressure finally! Peace of mind I guess lol so do you have a aftermarket pan or just welded the bung to the factory steel lower pan? Thanks!
I think what is happening is when you install the tee instead of oil constantly flowing over EOT sensor it now just dead ending that's why temperature is not accurate. I also tried extending EOT tip using copper piping worked okay but still not accurate that's when I decided to do the relocation in the pan.Thanks for the tip! I've been trying to decide how to get it to read correct again. I don't have reduced power, and don't play hard until I see my coolant up to temp. I'm just glad to see oil pressure finally! Peace of mind I guess lol so do you have a aftermarket pan or just welded the bung to the factory steel lower pan? Thanks!
What kind of oil pressure are you seeing ?
My 2012 with 10w30 45 degrees outside see at idle warm engine 34 to 39 psi. If I use 15w40 it will raise pressure by 8 lbs
Sent from my SAMSUNG-SM-G930A using Tapatalk
I've ran both H$S MINI MAXX ****** and S******* Ngauge on my truck. The H$S was effect most by the oil temperature.May i ask what kind of tuner u are running?
Can't quite tell but your Ngauge what are you using to mount it ?Changed up my mount, I just wasn't happy with the other one. This is a glow shift mount. I actually like it pretty well, I am wiring in a 4 pin connector to be able to remove the gauge if needed and not use butt connectors.. I hate that. Also going to tint the gauge face, way too bright at night or early morning with my windows being tinted.
