P20e8
Heavyhaul
Wyoming
Low redundant pressure. 2011 47,000. Its been at ford three times for this code. Now its up to me to fix it. They have put 2 pumps in it and a reprogram. Any experience or knowledge would help.
Rivets are the new duct tape.
POWER-STRUCK
Indiana
its due to pump priming delay, i believe it wants to see 50 psi within 45 seconds. an updated pump kit is available part# bc3z-5L229-L if you need videos just PM me
Heavyhaul
Wyoming
No other symptoms other than it goes into limp mode. I will have to check the invoices its had two new pumps in the last month. Never making over 100 miles after each one.
Heavyhaul
Wyoming
Just called the dealer to confirm. They have put 2 of those kits in already.
POWER-STRUCK
Indiana
i'm sorry, i was incorrect, that code comes down to reductant injector testing, you need pinpoint tests rk7-rk10
Heavyhaul
Wyoming
POWER-STRUCK sent me some good info. I will run tests tomorrow once I finish my other project and post results.
Heavyhaul
Wyoming
I think I'd find a new dealer, one that will fix the problem correctly.
Were already taking them 2 hours north. Next will be three hours south. Its going to be cheaper to fix it myself.
Heavyhaul
Wyoming
Ended up replacing the tank along with the pump again. Problem solved.
