PIP EGT sensor kit
drservo
Can the factory sensor be removed and replaced with this one to read EGTs or do you have to drill and tap the manifold per the instructions? 2015 truck
Mike07270
Best way is to get egr ****** with 1/8" NPT threads and install in plate
Radioflyer
Most of your aftermarket EGT sensors (edge, SCT, Isspro, Autometer, etc.) are 1/8" NPT thread. IIRC, the factory sensor is 1/4" NPT. As said above, get a kit that has the 1/8" NPT sensor bung already done. I.E, No limit's egr kit.
drservo
I have Nolimits kit, what do I do with the factory probe? Zip tie out of the way?
