With the spill port open stroke is limited by the distance from the bottom of the spill port to the bottom of the barrel. The stock injector does not use this full stroke. You machine them to get full use out of this stroke. There are two ways to increase stroke past this point, one is to plug the spill port. The other is to machine a spacer the will fit on the bottom of the barrel to allow more stroke to the bottom. This will leave your spill ports open and increase stroke. With spill ports open and no shims, the injector limit is basically 190cc. It is math, area of a cylinder. I can get you the dimensions if you want.
The distance from the bottom of the spill port to the bottom of the body is 5.65mm. The diameter of the plunger is 6.34mm. That makes the maximum volume 178.368.
absolutely correct...
but you can get MUCH more volume than that WITHOUT plugging the spill port...or changing plunger diameter
Yes, Yes you can.
You could easily add a 2mm spacer and get the injector up to 241.507 very easily. I would think that you may even be able to get close to a 3mm spacer and get the injector up to 273.077
Jess, not putting the spacer under the spool valve. Putting it between the bottom of the barrel and on top of the fuel plates. This will allow more downward travel. Issue is you have to deal with is bottoming out the return spring with the added downward stroke.
Edit: forgot about the body o-ring to nozzle nut, my bad.
There's a writeup in the new issue of diesel power mag that shows how to turn a stock injector into a 155/40 with Elite's DIY injector upgrade. It shows you how to take the injector apart and what needs to be done on making it a 155cc injector. The spill ports get plugged with some sort of plug that needs to get pressed into the body(spill port) until flush, then carefully hit the rough outer edge of the plug with a dye grinder to smooth it out. So plugging the spill port will turn a stock injector into a 155. Just thought i'd through this out there if guys wanted to check it out.
Has any tried just giving it a them little zap with a TIG welder?
