Powerstroked162
On Da Juice
The rust is def engraved in. But like i said i was just bored. Im cleaning the heads now, if they are cracked will i be able to see it?
Depends. If the cracks are big enough, you might. Although if they are big enough to visually see by eye glance, there will most likely be some symptoms along with it. Magna-fluxing the heads tells the tale. Most tiny fractures will be facial. In the area around the guides and seats, under the valve, you will see them if they are there. Sometimes the cracks will run passed the seats and cross from valve to valve. Unfortunately, if you have a crack that runs from valve to valve, across the combustion chamber, 9 outta 10 times the heads will be junked in favor of a new core set
