post your setup and dyno #s or track times
Stroker04
Gettysburg PA
Right around 45-50psi. I'm not sure why I'm having trouble. If it doesn't blow the ic piping off, the boot will give out and rip causing a huge boost leak[/QU
stop being a cheap ass and buy some better quality boots
I'm not being a cheap ass....they are pressure rated to 290psi and rated to 300 degrees. Mandrel bending solutions does not sell junk.
cmont58
Corryton, Tn
I know I'm late to the party but I ran an 8.64 1/8th in my 05 eclb 4x4, with Warren 190/100 injectors, Innovative tunes, stock everything else.
Strokin89
Manchester Maryland
Stock turbo? How's the smoke with the 190's?
2005 F250 6.0 powerstroke, 6 speed manual, egr delete, arp head studs, new oil cooler, aftermarket coolant filter, custom intake, 4" down pipe into dual 6" stacks, 8" lift, TSD super panty dropper tune.
TheReelMuhcoy
New Jersey
Last year XDP Open House:
This year XDP Open house, same dyno:
valvetick
I just tore my new 6.0 apart for studs etc and threw on a kc68, warren 190/75 injectors and a ported manifold and the truck ran a 13.3 @ 101 at 8150 lbs on my 35's. I was running gearheads reduced fuel tune I would like to try the full fuel once it cools off I'm in az so its still 90+ at night at the track. Here is the video I launched at 8-10 psi because I do not have traction bars and still running a bone stock trans.
http://youtu.be/kbSguZ9njxU
Strokin89
Manchester Maryland
Man that really makes me wish I had an automatic
valvetick
Are you saying the times I ran makes you wish you had an auto? My friend had a 6 speed in his cummins and swapped to a built auto so he could run a little faster down the track.
Strokin89
Manchester Maryland
Yea. Well drag racing in general the zf6 isn't the quickest shifting stick
valvetick
Ya I couldn't imagine trying to row gears in my truck. The turbo would never stay spooled with my shifts.
