post your setup and dyno #s or track times
TBagAMouseTrap
Windber PA
:whs: My last pass, 68vgt with factory up pipes and torque converter. Identical pass probabaly.
04cr450
harford county, maryland
thats a strong setup for sure. i like that combo. i rode in a truck with the same setup and was a totally different feel, in a good way, the truck flat out ripped.
ford rules
This makes me wanna run mine and see how it does.
I kept having boot issues also ended up buying dieselsite boots and double clamped everything i could and then welded lips onto the IC pipes so it would be harder for the boot to slip off
Stroker04
Gettysburg PA
how much boost Zach? When I ran my 64mm non vgt with the 190/75's I would hit 45psi and never blew a boot.
Right around 45-50psi. I'm not sure why I'm having trouble. If it doesn't blow the ic piping off, the boot will give out and rip causing a huge boost leak
