Power Running boards....Help?
Dtm030
FL
Hey guys I know this a diesel forum but I am installing my power running boards on my F150 and was wondering if anyone has done this before?
It's a 2011 F150 and the wires on the steps are supposed to match the ones on the wiring harness under the kick panel and they don't. It says you may have to just try them out and see which works but there are a lot of wires there and it could be any combonation?
Any help would be appreciated.
Dean.
RedSmokey
Sacramento, CA
I doubt they match your factory harness as its used for multiple years if its the amp steps. I would pull the door panel off and look around at the wiring. When I did my amp steps on my 01 F250 I had to search for the door ajar signal line, IIRC I found the sensor and looked at which line it was, then found the line where I would be splicing in and used a test light while pushing the button that makes the truck think the door is closed.
