Powerstroke swap wont start with key
Wasted Wage$
Project update
Got the key figured out. Ended up getting a pcm for a manual trans but I still doesn’t have throttle response or wont hook to a scanner I’m stumped Ive checked everything I can think of any info would be appreciated
Powerstroke Cowboy
Montana
When you push in the throttle nothing changes? As innit will not rev up?
Trying pushing the throttle in slowly by hand with your ear close to the pedal. Does it make a clicking noise as you push it in. It should sound like a switch just turned on. As you release it, it should click again.
Wasted Wage$
I’ve checked the fuses and none are blown.I’ll check the throttle pedal and make sure it clicks.
Powerstroke Cowboy
Montana
Nex
Yes have power to the tps.
Now, you need to verify power going out.
The voltage should change as the throttle is pressed and released. If you download Forscan on to a laptop or phone. All you need is a cable to go from the device to the OBD2 port. That can read throttle voltage as well.
Wasted Wage$
Update so I’ve went through this truck too to bottom and can’t seem to find any issues that are noticeable I’ve gotten a manual pcm and still no dice. Any chance it could be the IDM? I’m lost on this one
