Powerstroke214's build thread
Powerstroke214
Baton Rouge, LA
Looks like I'm getting a Trutrac next…
Powerstroke214
Baton Rouge, LA
Turns out, it gets a little toasty…hit 1762 at 3/4 throttle earlier today. So I'm gonna go on a limb and say that a 175/75 is too much fuel for a stock powermax. Guess I'll be trying to get a Barder over the Christmas break…
Powerstroke214
Baton Rouge, LA
Can't be a bitch all your life
Stfu, trying to justify more hp. Because I need to lower EGTs. Wait, isn't that with 2much/150 injectors? I have baby 175/75s
Then, I'm sure someone will be selling 190-205s that I'll end up buying, if I get a 68
How'd your injectors run? Mine are still kinda choppy, but I don't really wanna get away from ******** tunes. Zero actual issues and a little choppy idle is better than having to deal with trans issues or the light switch effect and smoother idle.
6l run a little hotter dont they? Whats a stock, tuned truck hit during a wot run?
Powerstroke214
Baton Rouge, LA
Just deal with the idle brother.
Tow tune runs smooth as glass. Keep getting an error when I try to upload the full fuel tune, but the RF idles funky. But I can deal.
Honestly, I don't know. Never had the balls to do a wot run before, as it wasn't studded lol. Highest I can remember was, I think, 14XX messing with Corb a couple years ago.
Cruising at 70ish it runs around 900°
I know it'd do 1010 at 100 stock
Now I wanna say it's 1250 or more @ 100
morepower02
MN
2005 with a atlas 40 ficm tune and various sct tunes since 2006 with no egt gauge here. Temps? A trained right foot lol.
scorpion67
BUTTE CITY, CALIFORNIA
My 6L ,stock turbo/injectors + sinister 58v ficm, no limit IC pipes which i doubt does much in my case for EGTs, will hit 1600 on ********s srl x or whatever is Matts hottest..
scorpion67
Powerstroke214
Baton Rouge, LA
So there's some minimal haze out the exhaust at idle. I don't know if it's to be expected with 175/75s or not. You can definitely smell that it's fuel smoke, and occasionally see it during the day, but it's mostly noticeable at night when there is light shining in the right spot. Also seems to either happen or I notice it after getting on it. I don't know if this is normal, a sign of injector problems or maybe something I can have mended through tuning.
Non-expandable pyro seems to have chit the bed, need to install my ISSPROs and probably get an EAS probe too.
And my biggest issue thus far is random surging/fluctuations in vane position. No codes. Usually when I'm cruising on the interstate, I see like 42-46% for vane position and around 6psi. Then it'll jump to 54-56% and I wanna say 9psi, maybe more. It's hard to see exactly how long it stays like this, because I'm usually going over overpasses so naturally vane pos. and boost are changing. While it's not the most quantitative measurement, the biggest thing that I notice is obviously sound. The turbo obviously gets louder and pitch changes since vane pos and boost levels change, but because those numbers fluctuate so much it's sometimes hard to tell how long this condition lasts. But driving it, the sound level/pitch of the turbo is noticeably higher than normal for whatever driving conditions. I'm not sure where to start looking into this.
Turbo is a Powermax, installed last July(2014) and has roughly 8k miles on it now.
Quick rundown on mods for more detail:
Air: Pmax, AP Apex JR mani
Fuel: Warren 175/75
Tuning: Matt's reduced fuel file
Truck is mostly stock.
