Propain injected stacks (flame thrower stacks) need info
GreasyFingers
wouldn't it ignite better closer to the top of the stacks and not so far down..... seams like it would be snuffing it out down there....
I'm with you on this. Down low there is fuel and spark but little to no O2. I've seen this on a few hot rods and the spark plug is within a couple inches from the tip and the LP is put in different locations for different affects. Closer with a nozzle makes it more torch like, further is more fire ball like.
Cobra 19 & 54
Scottsdale, AZ
I was rolling about 80 mph up a 6% grade and saw a SD in front of me putting out a 4 foot flame out the tailpipe. Turned out to be a messed up injector, but it looked wicked. Not stacks, just a 4" turbo back.
samoht517
Lakewood, CO
Seems like it needs air. Like on a propane or butane torch there is an air hole behind the flame a ways, so it might all need to be moved up
Mike For Mayor
Nice big flames spewing out the top of the stacks.. maybe gas injection will work better :demon:
Powerstroke Cowboy
Montana
One thing to keep inmind is with the pressure and air flow of the exhaust. You will have to keep the igniter as close to the gas as you can... I wonder how well a glow plug would work????
Jake P
I don't know if that would ignite the propane though. Some one needs to try it...
TurdHerder7.3
Topeka, Kansas
Glow plug in theory should work. It would be just like a hot surface ignitor on a furnace. Personally I like the idea of adding fuel at bottom of stack and ignition at the top but that would require a spark ignition. and what about one of those multi spark ignitors off of a grill with a simple extension of the wiring.
cowboy_dan
Brownstown, pa
Glow plugs are like 15$ each.... damn... oh fyi im using marine spark plugs
I think I still have a set I pulled out when I got my truck. They're packed away somewhere in a box. If I knew where they were I'd send a couple your way.
The spark plug should work if you have a good driver circuit. I doubt a relay is going to work.
Basically you use a 555 timer to drive a transistor, simulating points. Then the coil is running just like on a car.
schroederness
DeGraff, Ohio
I dont think a turn signal relay is going to fire fast enough as those are based on resistance. Turn signals blink faster when one bulb is out because their is that much less resistance. So in theory if the resistance was greater then it would actually go slower. Now assuming that a spark plug is greater in resistance than a light bulb I am going to assume that you are sparking slower.
That being said this shouldnt be to hard to do.. Move the fuel closer to the spark and have a faster/stronger relay.
Mike For Mayor
Why is it so damn cold! ! Unfortunately since its getting colder im finding it more difficult to get this done..
