DirtyJerseyStroker
I've been having a problem with the ESOF 4x4 system. I was getting the defrosters coming on when the 4x4 was turned on which indicated a vacuum leak in the system. I said to hell with finding the leak and replace all the 4x4 lines with new ones. Now that i did that the there are no vacuum leaks in the system but i am only getting 10 inches of vacuum at the hub line when switched on and nothing when i turn it off. Could it be a bad vacuum pump or a bad solenoid switch? I thought i could be the vacuum tank as well. I just recently ordered new ESOF hub locks so i can manually turn the hubs into the locked position for the winter. My old ones were completely frozen! If it may be the tank, is there a place where i can get one. I have found the ESOF Solenoid and the pump, but can not find the vacuum tank.
Thanks in advance!
Thanks in advance!
