Zmann
- Joined
- Aug 5, 2011
- Messages
- 4,464
- Reaction score
- 0
thats a dust seal thats technically not the knuckle the knuckle is on the other side of that
Hublock Operation
With the hublocks in the AUTO position, the 4X4 ESOF system uses timed vacuum sequences to lock and unlock the wheel ends when switching the instrument panel MSS between 2WD and 4X4 modes. A high vacuum level (222 mm [8.75 in] Hg and greater) is applied to the hublocks to lock the internal spring mechanism that engages (locks) the hublocks for 4X4 mode, and a lower vacuum level (114 to 184 mm [5.9 to 7.1 in] Hg) is applied to unlock the spring mechanism that disengages (unlocks) the hublocks for 2WD mode. The vacuum signals are supplied to the hublocks by system components, including the 4X4 control module, wiring harness, solenoid, vacuum harness and vacuum seals. As a first step in service, eliminate obvious items such as loose wiring connections, loose vacuum connections or damaged vacuum lines.
ps they have an updated dust seal that actually goes in the axle tube now for the later models 05ish up
Ok I tested the pump ( only pulls 8lbs ) tested canister( it holds the 8lb
) tested pvh (spiked to like 2 and dropped) now this t fitting I can seem to find anywhere
I also found this on my driver side knuckle
the pulse to lock the hubs is max at 8
but the drop points to checking each side at the knuckle input
