Rescaling MAF
CoreyMS
Anyone work on this? We have three tables, Max / Min Air flow metered by the MAF sensor and a Curve to transform sensed value to Maf Rate.
In my mind I multiply all three tables by the same amount to equal the change in intake diameter.
judeisnotobscure
Why are you rescaling the maf? Did you install a larger maf housing or are you attempting to underscale your tune?
CoreyMS
5 inch intake.
I ended up raising the curve and max tables and lowering the minimum table. It seems to like it so far.
