SCT SOTF (Shift on the fly) GH/AS REVIEW
8WR_ZJ
I just got the same code when i towed my 5th wheel. That's the only time i go to position 1.
Jomax
Arizona
Jomax did you ever get your truck back with sotf? Just wondering why I never got the code yall got lol. Been running it for a while and everything has been fine, although I never take it out of level 5 unless I decide to start fking around with it, which doesn't last long before its back on 5. Just wondering if their is a newer sotf tune out
No I didn't, it's me really, haven't messed with it. The race tune never changes lol. I need to plug it back in and try it again, being I changed some stuff when I was having CAC issues.
TexAg56
Corpus Christi, Texas
If for any reason I did switch tunes to old non sotf from GH or I also have 1 tyrant tune, could i leave my sotf cable plugged in? Or would I have to unplug it and plug back in the sensor? Will probably never happen but just good to know
Jomax
Arizona
Unplug and plug the sensor back in.
OutlawII
Just installed all the goodies yesterday,little confused . When loading the custom tunes (Tyrant) there is two files in there one says sotf the other says No power. I loaded the Sotf one. What is the other one for?
Serial Fordicator
In case the sotf breaks you have a backup tune to load
brock1129
I just received my switch yesterday. Is this the new version of theswitch or still the old?
bigrpowr
<How I Fly
Administrator
there is an updated version for the 11-12 . once all the existing switches for 13+ are gone, it will be the same switch for 11-16 for for all tuning that uses CACT as the reference.
TexAg56
I still have yet to get a CEL lol. Although I never drive on level 1.
Do any other tunes for the x4 use the same switch that GH uses? I know other tunes plug into other places than the CAC like gh does. Just wondering if I could switch back and forth between tunes using the same switch.
Jomax
Arizona
Mike should have tyrant tunes that work on it. But honestly that's a question only Mike can answer. I honestly have no idea.
COF350
Temp didn't work, it showed like 60degrees or something close to that as a default I assume?. Switch is plugged into the CACT sensor hole.
Right now I'm back to my old race tune. My truck is a finicky pig. Computer didn't like the CACT sensor being unplugged as the fuel rail temp sensor was going crazy not seeing it. Mike is fixing it, so until then I'm back to my old reliable tune.
I do miss the SOTF though!
Did you ever get this sorted out? I am having the same problem with CEL and SOTF GH tunes. Every time I call and email I get the run around that "they are working on it." Tempted to go back to a single tune as well.
bigrpowr
<How I Fly
Administrator
these can be very tempermental. call tomorrow and ask for me. extension 101 , i'll fix it.
Jomax
Arizona
Honestly. Never tried it again. Truck never leaves the race tune. It's kinda nice just forgetting about tuning and what not. I just drive the piss out of it. I do want to try it again. But work is keeping me busy. I have a list of things I need to do on the truck. Lol
