Should I weld it?
Jan 17, 2015 #21 Magnum PD Active member Joined May 18, 2011 Messages 9,566 Reaction score 7 Location VA
Jan 17, 2015 #22 Magnum PD Active member Joined May 18, 2011 Messages 9,566 Reaction score 7 Location VA
Jan 17, 2015 #23 Magnum PD Active member Joined May 18, 2011 Messages 9,566 Reaction score 7 Location VA
Jan 17, 2015 #24 Magnum PD Active member Joined May 18, 2011 Messages 9,566 Reaction score 7 Location VA
Jan 17, 2015 #25 Magnum PD Active member Joined May 18, 2011 Messages 9,566 Reaction score 7 Location VA I hope it seals up fine. Don't see any major gaps.
Jan 17, 2015 #26 psduser1 Active member Joined May 22, 2011 Messages 3,815 Reaction score 20 Location on the road Looks good online! I'd love to build a similar setup, even with a 38r, just can't justify the time on a setup that's working, lol. When a new block goes in, maybe. If your worried about gaps, use some blueing to check for contact.
Jan 17, 2015 #27 Magnum PD Active member Joined May 18, 2011 Messages 9,566 Reaction score 7 Location VA Even did some gas welding on the down pipe. LOL Had to down size it to my smaller pipe.
Jan 17, 2015 #28 ja_cain Active member Joined Aug 10, 2013 Messages 4,597 Reaction score 2 Good stuff. I learned to torch weld first but haven't done it in a while. Need to revisit it. Did he bevel the but welds as the beads look pretty flat.
Jan 17, 2015 #29 Magnum PD Active member Joined May 18, 2011 Messages 9,566 Reaction score 7 Location VA Around the bolt holes, no. Had enough space to get weld in.
