powerstroke 825
So to get rid of the passenger side I just need some heavy wire to run from the starter and alternator over to the driver side?
You will be better off mounting a bus bar power post somewhere. Run all the cables that are on the passenger side to that and then run one heavy cable to the driver side. On the driver side there is really only one cable that gets power from that battery. That's for the fuse block iirc. The passenger is the more important one. Don't let the cables dangle IMO. Looks shady and can cause issues.
did you get rid of the driver or passenger? I wanna get rid of the driver side but not sure what is the best way to handle the coolant tank
Here's two pics I had on my phone. I'll get better ones with more detail. It's nothing special the way the batteries are hooked up. Two type 31 series batteries. Can't go wrong with them. I'll get better pic of the coolant tank when everything gets back from coating.
