Single numbers vs compound dyno numbers
swinky
Eastern, Nc
What about a gated 369 and spray? Should be able to hit 800 plus and drive very well.
Grand Junction, Co
S369 as a single would run really well even with the elevation IMO. Gonna be running it in compounds on my build soon.
I think his original post was where the power curve comes in with comparing compounds to single not so much the peak power factor. It's just like you can push past 800 hp at around 2500rpm with compounds vs with single would push it out to closer to 3k before it makes 800hp. Which brings it all back to the streetable setup. if your gonna run a decent size single with factory converter stall rpm you will most likely hate life on the street but with compounds it would not be any issue.
timj
Wisconsin
My stock trans was toast by day 2 after I put on maxpowers and 100's. And it only made it past the first day because I had a fresh built engine and didn't take it past half throttle.
